Page 62 of 154 FirstFirst ... 125258596061626364656672112 ... LastLast
Results 1,221 to 1,240 of 3070
    Aug 2012
    #1221
    actually, it depends on you. if you are satisfied with current sound quality and just want higher volume, then no need to change. does your HU have PRE-OUT (RCA) ports to connect to the new AMP?
    Aug 2010
    #1222
    Quote Originally Posted by artsky View Post
    Tanong ko lang, ganun ba talaga "ka-pangit" ang sounds ng stock headunits kaya need palitan if you want better sound? hindi ba puedeng lagyan na muna ng amps at change stock speakers? Ok naman kasi sakin yung tunog nung stock HU ng Vios 2013 pero yun lang need ko ilakas yung volume para may bass or mapuno nya ng sound yung loob ng car. Sa ganitong case ba ng listening style ko, palit HU ba ang better route?
    Nope. I've heard of a Civic FD's stock head unit with a complete chain setup (speakers, amplifiers, and subwoofers) and it sounded quite nice tonally naman.
    The only reason you want to change the head unit is when you feel it's the weakest chain of your system. For many, these is usually the need for a flat signal or the need to remove the stock HU filters. The more "enthusiasts" ones will tell that you need the better features of more EQ bands, crossover controls, time alignment, etc.
    That prevalent misconception is why one of the goals while I was building my concept was to debunk that myth. The result is that I professionally compete using my stock head unit...
    but with an incredibly creative (aka do-not-do-it-to-your-car) signal route that preserves the quality of the signal I have from my iPhone.
    Apr 2008
    #1223
    Quote Originally Posted by jhnkvn View Post
    That's probably the head unit's "mother" board na mismo. In theory, it might just be the CD mechanism if lagi bad disc yun CD but since the SD slot is also affected, I'll suspect that it's the board itself.
    Hindi ba pasok sa warranty ni Hyundai PH? Since that's going to cost a lot for repairs (almost brand new cost na yan)
    Ang hassle pala. Ang hirap ipagawa sa casa since wala talagang oras. Alam mo naman... Schedule pa ng appointment, ang haba pa ng pila, makipagkulit-kulitan pa sa mga warranty personnel nila and so on and so forth.
    But then again, bat natatanggap pa ang GPS SD card? Kung sira yan diba dapat pati yan di nababasa?
    Marupok ba talaga tong mga OEM AVT head units?
    Sent from my GT-I9100 using Tapatalk 2
    Aug 2010
    #1224
    Quote Originally Posted by GTi View Post
    It's not the SD card mechanism but rather how it reads the files. GPS data is handled by another decoder so it's unaffected while turning digital audio files like .wav, .mp3, etc. to something that can be read by your head unit lies with the DAC chip on the board and that might be the one which is defective. The reason why it can't decode is most probably the culprit of your error message of "bad files". Problem is, your DAC chip is central to the head unit's operations and it's like changing the CPU unit of your computer. Most manufacturers would rather say that you replace the entire board instead since what they usually get are finished-units na with their board assembly being outsourced to low-cost production countries like Taiwan.
    That's my guess anyway.
    Apr 2008
    #1225
    Hmm~ Kung sakaling ipa-warranty claim to sa casa, ihohonor pa ba nila yun kapag hindi na sakanila nagpapamaintenance? Supposedly walang kinalaman dun ang head unit, but would they find ways to weasel out of it?
    Aug 2010
    #1226
    It should be honored. But what I'm afraid is that they'll juggle you between the CASA/Hyundai and AVT Philippines.
    Sep 2014
    #1227
    ano po kaya problema ng set up ko.
    im using 1 amplifier,crossover switch, 1 16' ata na sub then 4 na seps.
    eto po problem. sobrang basag yung tunog ng mid range pag dumaan sa amp pero pag sa head unit naka connect okay naman ang tunog. wala naman problema sa sub. Minsan okay naman tunog kahit sa amp naka kabit.
    #1228
    Quote Originally Posted by zen.. View Post
    Baka di naka-set maayos ang amplifier gain setting...
    Posted via Tsikot Mobile App
    Dec 2007
    #1229
    How many channels does your amplifier have and how many pair/s of components/seps is the amplifier powering?
    Feb 2011
    #1230
    After getting a new car, how long do you have to wait before upgrading your audio system? Medyo critical kasi if electrical warranty ang ma-void.
    Aug 2010
    #1231
    Quote Originally Posted by sientobente View Post
    Most people wait until their electrical warranty is up. Although, technically, the CASA can't void your electrical warranty unless you spliced a wire here and there. As for me, paglabas palang ng casa direcho na
    Jun 2010
    #1232
    ok lang ba na ang subwoofer (10") and 2-way seps to be powered by a single 4 channel amp or mas ideal na may separate amp ang subwoofer.
    Feb 2014
    #1233
    Mga master any review about Precision Response Amplifier? Ill wait for your reply.. TIA
    Dec 2007
    #1234
    Quote Originally Posted by enargie View Post
    No need for a separate dedicated amplifier for your subs if you have a 4 channel amp powering a pair of components and s sub woofer. The only time you add a separate amp for the subs is when it is obvious that the subs needs more power.
    Sep 2014
    #1235
    Quote Originally Posted by markygy View Post
    4 channels po. Ch 1 and 2 naka bridge for the sub . 3 and 4 sa front speaker. Na pag alaman ko po na distorted lang is yung ch 3
    Aug 2010
    #1236
    And dahil distorted, ayan ang culprit ng iyong problema..
    #1237
    mga paps...patulong...i have HSK 163 (3-way), amp would be LRx 5.1k and I'm planning to have it semi-active. But not the usual 3-way semi-active wherein TW+ Midrange for amp A-channel in A-pillar, and Midbass for amp B-channel. Question is:
    would it be advisable na ang TW for A-channel, and midrange + midbass for B-channel? Midbass would be in stock location, and midrange would be in kick panel, while the tweeters would be in a-pillar?..
    doing so will make the soundstage larger and for additional depth? and to avoid that "in your face" sound?...
    what would i be facing in this kind of setup?
    TIA
    Feb 2011
    #1238
    Quote Originally Posted by kuniknok View Post
    Hi,
    Is that an amp you got from a local dealer?
    Oct 2008
    #1239
    Guys, anong headunit ang may magandang display. Hanap ko sana yung tipong madaming VU meter bars then may peak hold. Yung mga touchscreen ba na pioneer may ganyan, or this feature exclusive lang sa mga old vacuum-florescent displays?
    Jun 2010
    #1240
    Sir, need advise for the specs of 4 channel amp I need to choose to power a 10" sub and a pair of 2-way seps.
    Thanks
audio set-up for beginners [continued]
