Results 1,011 to 1,020 of 3070
- Mar 2014
- 63
April 30th, 2014 03:28 PM #1011Sir intact naman fuse and fuse ng headunit. Iniisip ko if yung speaker ang may problem. Possible kaya mag cause ng ganun na problem?
Posted via Tsikot Mobile App
April 30th, 2014 04:31 PM #1012
- Mar 2014
- 63
May 1st, 2014 12:47 AM #1013Tinangal ko yung fuse then in off ko sa setting ng headunit. Nagpawiring ako along banawe. To update lang nakita ko na culprit. Nagtrace ako ng mga wires to check polarity and kung tama pinagkabitan at ayun may mali sa polarity ng subwoofer to amplifier. So far di siya namamatay.
May 1st, 2014 03:17 AM #1014
May 2nd, 2014 02:05 PM #1015
May 3rd, 2014 05:32 AM #1016
my problem is tuning my system...parang hindi ako satisfied sa sq..or i missing something?
heres my setup
hu x4650 - set to 80hz fronts
amp1 focal 4.75 le bridged 2x200w rms in full range, gain 40%
amp 2 focal 1.800 on 80hz 600rms x1 *2ohms
sub focal 33v2 400w *2ohms
fronts morel tempo 110w rms
front doors fully dynamat
im satisfied sa sub output it gives me a nice solid bass on sealed box
problema ko parang may kulang sa fronts ko..
May 3rd, 2014 06:22 PM #1017
Easy. You aren't tuning it well.
Your head unit isn't capable and you don't have much channels to take advantage of it.
And from my opinion, you splurged too much on the subwoofer.
May 3rd, 2014 07:50 PM #1018
^ so i need a processor?..ms8?.some people use the same sub amp combi just like my one ..i know bitin yung 33v2..but sa pandinig ko satisfied na ako..i just lower the amp gain...
- Jun 2011
- 91
May 3rd, 2014 08:29 PM #1019Question guys. Sinu-sino po naka-underseat or bazooka type na active subwoofer dito? I was planning to buy one, pero i need your input kung alin sa dalawa ang maganda. Gusto ko lang naman po na may konting BASS yung mga songs ko from 2650ui. TY sa mga sasagot po.
Requirements ko po eh, may remote to control yung bass response niya mapa, unerseat or sa trunk.
May 4th, 2014 02:47 AM #1020
Pardon on my last post. I was kinda tired when I made that and my thoughts were jumbled haha.. looking at it right now makes me sad since naooffend ako sa sarili kong post
here's a more extensive reply.
Actually mahirap magpost oz.. since I'm not too sure on what you're aiming for nor what are your standards.
First thing I need to clarify is your standards. Are you trying to achieve the true "SQ" that has good tonality, staging, and imaging? Have you heard of one?
If not, I suggest you try finding one to hear. It will turn your idea of great sound quality around. You already have the gears for it so you just to re-wire some stuff, throw in an external processor and find a person to tune it.
Second is I want to know who your installer is because it gives me an idea on whether how experienced the installer is or not if I will try to recommend processors.
But let's try to solve your current problem muna.
By "kulang yun fronts", that will mean one thing: The front isn't loud enough.
The easiest way on how to solve this is to dial your subwoofer down because your front is being overpowered by your subwoofer. You can do this via your head unit (subwoofer level) or via your amplifier (gain control).
You might want to also experiment lowering the crossover for the mono amplifier. Setting it to something like 63hz will lessen your subwoofer's reach into the midbass and should give you a more prominent midbass which in turn enhances the front stage.
Your subwoofer performance is largely dictated by your box rather than the power you throw it ;) Even when I juke it out heavily, I'm using less than 500W of power and my box isn't that big either (1.1cu.ft volume). I know of this due to my fuse which is at 40A (40x12 = 480W).
Hell, I usually tell people that if you're geared towards "SQ", you won't really eat more than 400W unless you built yourself one heck of an inefficient enclosure.
For the processor choices, since you're just doing a 2-way setup.. something like the Mosconi 4to6 and the Audison BitTen will suffice which is at the 16,000php price range. No need to go into the 30 grand price range ;)
If you plan on going for the processors, ask your installer first which processor is he comfortable in using. I will also be recommending a manual tuning processor and the MS8 because... well, it's promise of auto-tuning is incredible.. but it's not something I will recommend for people looking for a plug-and-play solution. It kinda needs some "work" for it to sound great.Last edited by jhnkvn; May 4th, 2014 at 02:51 AM.
I disagree and wouldn't advise that. Additives get used up too, so topping up with the proper...
Coolant...
