Results 851 to 860 of 3070
December 9th, 2013 10:45 PM #851
inaccessible yung website ni mickey. ganda pa naman mag-refer ng specs at prices dun. i hope ma-restore nila ulit soon...
December 10th, 2013 01:17 AM #852
December 10th, 2013 01:39 AM #853
December 10th, 2013 03:26 AM #854
- May 2013
- 37
December 10th, 2013 01:33 PM #855Sir inputs bout these amps?
Hifonics Brutus BRX640.4
Precision Power S580.4
Precision Power BK800.4
Cadence FX2400.4
Thanks guys.
December 11th, 2013 02:00 AM #856
- May 2013
- 37
December 14th, 2013 10:15 AM #857Guys, need ko lang ng amp na mga 4500-5000 range lang. If may suggestions na mas maganda dito sa pilipinas, please pasabi.
Kunin ko kasi from the states itong mga choices ko kasi mura.
Cadence Flash FXA2400-4
MB Quart OA800.4
Precision Power BK520.4
ito lang kasi mga $100 na parang maganda. if may suggestions kayo dito. I asked around kasi dito sa mga shops and for 4000 they're just offering mga "Q-amp" brands.
Cadence 2400 = 150 x 4 / 600w x 2 bridged (4ohm)
MB quart OA800.4 = 100 x 4 / 400w x 2 bridged (4ohm)
Precision Power Black Ice 520.4 = 95 x 4 / 260w x 2 bridged (4ohm)
Iniisip ko if pwede ba yun cadence kasi parang sobrang taas naman nung RMS niya, gamitin ko sana with JBL 609c na kukunin ko dito nalang pagpapakabit ako. wala naman ako makita na spec sheet nung cadence from their site kaya medyo hesitant ako. Pahelp lang sana. Need na kasi decision today kasi pabibili na ko para abot before christmas. Thanks guys.
December 14th, 2013 11:35 AM #858
Precision Power Black Ice.
You won't see them in the Philippines... Sedona parin ata yun binebenta ng mga tao dito. Even then, PH prices are priced exorbitantly when the products come from the United States.
I don't like the Cadence because they publish peak numbers. I don't like the MB Quartz because they're marketing their topology as an "SQ" topology which there isn't.
The difference between 95W to 150W is simply 2 decibels. Stop placing too much emphasis on wattage. Place more emphasis on speaker efficiency -- driver sensitivity if you want something loud.
- May 2013
- 37
December 14th, 2013 01:25 PM #859
December 14th, 2013 05:10 PM #860
Yes it is. Just make your subwoofer more efficient. A subwoofer's performance is way dependent on its enclosure more than anything else.
I can get a subwoofer, throw it in a ported 3cu.ft enclosure then feed it 300W to beat the exact same subwoofer but in a sealed 1cu.ft enclosure and feed it 1000W of power and still the 300W will be louder. Given this, it's best to simply optimize the design of an enclosure more than feeding it more power (which translates into lesser fuel efficiency btw)
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
