Results 841 to 850 of 3070
- Sep 2010
- 7
December 6th, 2013 03:47 PM #841good afternoon guys.
tanong ko lang sana kung open parin ang tsikot.com store sa bicutan?
gusto ko kasi painstall ng sound deadener
thanks
December 6th, 2013 04:11 PM #842
A battery simply prolongs the time you can play with the engine off. If your engine is running, your alternator is your source of power. The only time you'll tap into the battery for power when the engine is on is if a hard bass drop hits and your voltage goes down to battery 12V levels.
The difference between batteries such as Stinger with our everyday Motolite is that they're designed for different applications. The main difference is that Stingers are designed to be drained and recharged frequently. Do that to a Motolite and you'll severely cut the lifespan of your Motoline battery.
For what it's worth, I'm just using an Amaron battery if that'll give anybody peace of mind as to which battery should they get. My batteries don't last long though.. my last one just lasted 2 1/2 years. I kinda attributed this since they're being drained at times (especially on days when I want to crank my volume up). Ok na ako sa 2 1/2 years rather than paying double for Stinger battery that will last probably 1.5x longer.
December 6th, 2013 04:45 PM #843
December 6th, 2013 07:55 PM #845
- Nov 2012
- 79
December 7th, 2013 11:15 AM #847
You'll both be receiving PMs
In any case, I usually tell people to meet me in Banawe since.. it's the car enthusiast mecca. I'm usually free on the evenings (7pm onwards) although I don't really mind making time during the day or noon.
Or if you can wait, you can always find me in Tsikot's EB (http://tsikot.com/forums/car-shows-a...ml#post2275246)
December 7th, 2013 08:47 PM #848
- Nov 2012
- 79
- Aug 2008
- 13
December 9th, 2013 10:05 PM #850Had my audio set up by mickeys. JL audio c2-650 seps, infinity 6502ix coax for rear fill, RF JPS 1008 underseat sub, jbl gto 804 ampli plus deadeners on front doors. Went over my budget but couldn't be happier, parang lumulutang sounds sa loob ng sasakyan ko. Stuck in traffic? Nooooo problem : )
Thanks jhnkvn for bearing with a newbie :bowako
It may be variable speed I think. It's slowly being used on cars that either don't have an ICE, or...
A/c
