Results 681 to 690 of 3070
- Aug 2013
- 6
August 1st, 2013 03:20 AM #681
August 2nd, 2013 09:30 AM #683
currently have front door separates power by headunit. contemplating on diy install of amplifier and subwoofer.
can anyone give step by step install procedure?
did some reading on the net but not sure... bale hindi na gagamitin yon stock speaker wire to front door and kailangan put new wire from amp to crossover?
how hard is it to snake speaker wire thru the rubber grommet of front door?
everytime mag on ng radio naka on rin amp?
August 2nd, 2013 10:07 AM #684
Mas advisable talaga new wires from amp to speakers para mamaximize mo yung output ng amp for the speakers
Placing wires sa rubber grommet?! Depende sa sasakyan. Usually pag first time gagalawin, may kahirapan plus kung maraming dumaan na oem wires sa rubber grommet, it will take time na maisuksok yung wires.
Everytime mag on yung radio nakaon din yung amp? Yes and dapat...May remote wire output from the headunit to the remote input ng amp which is responsible for this...kasama na yang remote wire for every wiring kit you will buy...
Happy DIY. Pero kung alangang gawin, mas okay parin painstall nalang...ako, when i was starting with car audio, nanood-nood muna and observe...after when may knowledge na and lakas ng loob, ako na naginstall...
August 2nd, 2013 12:23 PM #685
Head unit -> <RCA or Speaker-level out> -> Amplifier -> <wires> -> Crossover -> <wires to tweeter and midwoofer>. Your typical 2-way setup with passive crossovers.
You need not be fussy in the wires really. Not much need in branded either. What you need to look out for is that they're of proper AWG depending on the length you'll be running them. Most would go for 18AWG.. although it won't hurt to go for 13AWG (which is what I typically use) if you'll be wiring them on a longer length. If you're using rather old wires, check for oxidation.
Everything else is answered by mateomarco
August 11th, 2013 09:12 AM #686
okay lang ba i connect ang speaker wire (from amp) for front separates sa wire harness directly sa likod ng headunit?
August 14th, 2013 10:22 AM #687
^ add to question above...
or mas better put new speaker wires goin thru door grommets?
August 16th, 2013 01:44 AM #688
Mga bossing anu magandang brand and model ng 10" na sub na di lalagpas ng 5k?
Nasunog ko kasi yung DD 510 LE ko e.
I'll still use my enclosure, sayang naman kasi.
August 16th, 2013 09:59 AM #689
Pwede...tried this in one of our vehicles...i installed a sub and a 4 channel amp...two channels bridge for the sub then yung natirang two, yun yung tinap ko sa wiring harness...no plans of replacing the oem seps kaya tinap ko nalng sa amp...wala narin akong budget and time for additional speaker wires...okay naman tunog pero cant handle louder volume kasi naclicliping na of course...if you have time and money, much better kung bagong speaker wires from amp to speakers...pwede kung sa pwepwede pero "half-baked" para skin...
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
