Results 581 to 590 of 3070
April 16th, 2013 11:53 PM #581
April 17th, 2013 01:23 AM #582
April 17th, 2013 03:46 AM #583
Monster ba? Even I'm worrying about my stock alternator nowadays
My amplifiers are old na.. the Audisons are since 1999 pabut the good thing about good amplifiers is like buying a pair of great shoes. You could say they're an investment. Not every amplifier is stable all the way to 1 ohm. And I "require" the amplifier as my 6KRX3 midbass is... fussy about its impedance load. How did I get that information? By emailing Focal's distributor in the United States --- Orca.
As for the power, a total of 1830W (110x4, 120x4, 350x1, 560x1) at 4ohms I guess?Let's not get into 1 ohm loads, since the amplifier on the left (above picture) is capable of 2000W at 1 ohms :naughty2: how much is 2kW? Uhh... electricity load of two 1HP aircons I guess.
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 17th, 2013 11:33 AM #584how much is 2kW? Uhh... electricity load of two 1HP aircons I guess.
You have impeccable taste in amps and a car audio guru!
April 17th, 2013 03:56 PM #585
Mga sir magkano ba pricing ngayon ng re audio srx or se x 10inch. At ano bagay na amp para dito. thanks
- Jan 2013
- 58
April 18th, 2013 11:00 PM #586
April 19th, 2013 07:37 PM #587
*jhnkvn idol what can you say about the Pioneer AVH-P3450DVD and Pioneer AVH-X4550DVD?
2DIN na gusto ko ngayon e, nagbago na isip ko. Saka anung shop ang mairerecommend mo saken? Thanks.
Pioneer Philippines
April 20th, 2013 12:45 AM #588
Looks the same. As with Pioneer's models, the X-series are the newer ones which also means they're more pricey. Personally, kung malaki yun difference ng dalawa, doon ako sa P3450. If they're equal in price, ede doon ka na sa masbago.
As for shops, most of those in Banawe are competent shops naman. It's hard to go wrong just picking a shop that caught your eye (ex. maganda yun babae sa shops kaya doon ka magpapagawa) Changing of head unit is not an advanced technical skill after all
April 20th, 2013 12:47 AM #589
Can't help you with price quotes. However, I do suggest matching the amplifier to a mono amplifier that is at least 1 ohm stable if you plan to drive it hard. No such thing as brand matching really.. a speaker driver will only care on how much watts is being fed into them.. it won't care if it's watts coming from Brand A or Brand B.
Thread was made nung 2018 pa po sir.
