Results 471 to 480 of 3070
June 18th, 2012 08:53 AM #471
June 18th, 2012 02:12 PM #472
Depends on your definition of "simple". For most, just a change in speakers is okay na. A complete speaker-amplifier-subwoofer setup could cost you around Php10,000 at the minimum though. For SQ competition purposes, a minimum budget of 60k is preferred although the only thing that's expensive in budget SQ installs is the head unit - you need a HU with time alignment capabilities at least and the cheapest one costs 10k secondhand and 16k brand-new. But for LnC and SPL applications, entry cost is much lower as long as you don't exceed more watts than your alternator gives out. In most cases, a 1000W mono amplifier and the-biggest-sub-with-big-box is enough.
Any Pioneer AVH unit would do. Just choose one according to your needs. Cheapest one is the 1450.. and I think your budget maxes out at 3450 or 4350 Pioneer units. I'm unfamiliar with the differences sa products so just look for enough pre-outs (2 or more [more is better]) and your "wants" (ex. playback capabilities, screen size, etc.)
Depending on your vehicle, you could also opt for those OEM integrated systems that has GPS and shiz (much like the HU of the 2011 Monty) but these aren't really my head units due to limited tuning features.
June 18th, 2012 02:57 PM #473
sir, ano sa palagay mo ang magandang Pioneer AVH series na mai-recommend mo na swak sa budget na Php20-25k? mas prefer ko pala na HU yung USB and/or Ipod/Iphone ready na...
tia!
edited...Last edited by ecneret; June 18th, 2012 at 03:29 PM.
June 18th, 2012 03:09 PM #474
June 18th, 2012 06:31 PM #475
mga sirs may iclarify lang po ako..i own a toyota innova J. it has only 2 speakers.i plan to add 2 sa 2nd row.co axials lang sana. i've got my eyes set on an alpine co axial. bale eto po specs nya:
RMS: 35W
peak power: 210W
frequency range: 30-25000HZ
sensitivity: 92db
ok lang po ba eto? or may ma suggest pa sila na mas maganda..
do i still need to add an amplifier? bale yung front speakers ko,stock lang muna. i have an HU,equinox brand.aside from stock na electronics, may additional ako na 5 door central lock,alarm,led light sa spoiler and led lights sa side mirror.i also plan to add 2 headrest monitors din pala.concern ko din po kasi yung alternator ko..your inputs would be much appreciated.thanx
- Apr 2011
- 21
June 19th, 2012 12:41 AM #476
- Apr 2011
- 21
- Apr 2011
- 21
June 19th, 2012 06:25 PM #479
June 19th, 2012 08:17 PM #480
Okay lang po ba eto? Yes.
May masusuggest pa sila na masmaganda. Most speakers in this price range sounds relatively the same.
Do you need an amplifier?. No
Alternator? Kayang kaya.
As for the headrest monitors, I'd do it with a grain of salt. May mga kids ka ba that would be watching at the back? In 90% of people I know that has them, nagsisi sila. Buying a portable DVD might be a better alternative really.
I disagree and wouldn't advise that. Additives get used up too, so topping up with the proper...
Coolant...
