Page 12 of 154 FirstFirst ... 289101112131415162262112 ... LastLast
Results 221 to 240 of 3070
    Aug 2010
    #221
    Quote Originally Posted by Snoop23 View Post
    about po dun sa v12 amps..
    hindi po sirain ang v12 amps nasa gumagamit parin po yan kahit gaano pa yan kamahal kung hindi mo naman iniingatan eh wala rin..
    marami po akong kilalang mga naka v12 amps na taon narin ang binilang at hindi pa naman nasisira ako mismo naka v12 amp at wala naman akong sakit ng ulo.
    nasa gumagamit parin po yan.
    True in a way. However, don't expect too much. V12 amps generate excess heat rather than translate these into power.. if you can go for quality amps, go for them instead.
    Apr 2011
    #222
    Do you guys know how to change the rear speakers of a 1996 honda civic VTi? I want to do it myself so that I can save. hehehe. thanks in advance.
  3. #223
    First, you have to remove the backset, and the rear pillars in order to remove the rear dashboard, then you have the access to the speakers, there is a wire going to the third brake light, so you have to remove the socket first to finally remove the dashboard, you save 350 pesos by doing it yourself, goodluck!!
    Apr 2011
    #224
    Quote Originally Posted by jhnkvn View Post
    i know someone from cavite who nailed a decent 141db using a v12 710 and 2 pcs 15 inch targa not bad considering that its way cheaper than those well known brands. =)
    Aug 2010
    #225
    If it's for SPL, I won't complain about it. But if it's for SQ, that's another thing wholeheartedly. Besides, what I emphasize is a V12's lack of quality materials. The analogy is like that of an engine: You can take a GT-R's engine and let it run at 7000RPM continuously. You can then take the Vios engine and then run it at 7000RPM. Can the Vios take it? Yes. The question is... how long? And that's what I'm trying to get to.
    I know many car audio enthusiasts started out with a V12. My friend did and he loved every moment of it. However, it is for a fact that in the realm of car audio, what you pay is what you get (let's say they're all equally tuned to sound good).
    Apr 2011
    #226
    how about the vios made by sun x before using straight v12 and targa sir? (sq champion) even beat the high end brands.
    Aug 2010
    #227
    Which competition? I could easily enter my car and win any other SQ competition. Sadly, not all audio competitions are "SQ-grade". Best stick with the big ones if you know what I mean ;) Targa's really good once tuned, in fact I could say that out of all budget setups, Targa and Dominations show their best after tuning and could topple even higher-classed brands (I also like JBL amps). But if you try entering EMMA or the previous IASCA with a V12 and a Targa, I highly doubt it would win even in the 60k category.
    But that's really interesting. Kudos to Eric if that so.
  8. #228
    Two things are even, but need to be know what was right, here is what i have to say as a pair for the people who really need a good information...
    There seems to be a never ending stream of advice when it comes to car audio. Some of it is good but much of it is bad. Some of it is very bad. The real problem is those that need good information the most have the hardest time determining what is bad information. I've picked out some of what I believe to be the most common sources of bad information.
    Forums
    In my opinion the worst offender of bad advice comes from forums. On a forum you have no idea who people are, their background or what qualifies them to give any kind of advice. The post count by their made up username doesn't mean they know what they're talking about. It only means that they like to talk. They might throw their two cents in even when they're totally clueless on the subject. I'm sure you know people in real life that are just like that. Well those people have computers and an Internet connection too.
    Always keep in mind that you almost never know who the person is behind the forum name. There are very few true experts on most forums. Mainly because they don't have time to fight with every know-it-all that chimes in with "the answer". There are plenty of posts that say things like "XYZ sucks. My friend built a box for two of their subs and it sounded terrible". Well, maybe your friend's an idiot. Did he build the box to the right size? Did he even know what size to build it? Did he brace and seal it properly? What kind of material did he use and how thick was it? No one tells you those details. They just say don't buy it and move on to crap on another post.
    One of my favorites that I see come up again and again deals with fiberglass layers. It usually starts with someone asking "How thick should my fiberglass box be?". That usually follows with someone saying it should be 3/4" thick. Why did they say it should be that thick? Because somewhere along the line they were told that subwoofer boxes should be 3/4" thick. Well, that may be somewhat true if the enclosure is large and made out of MDF but it has nothing to do with fiberglass since they're two completely different materials. And even with MDF that's just a guideline that varies with many other factors. Then someone else will come in and say it should be seven layers or twelve layers or whatever they used the one time they made a fiberglass box. That information probably has nothing to do with the project being discussed. The number of layers or thickness of a fiberglass enclosure depends on many things and answering the question without knowing these factors is a the same as guessing.
    My other favorite is whether a subwoofer box with multiple woofers needs to be divided. There are guys who are absolutely convinced that a subwoofer box needs to be divided if there is more than one woofer in it. Others are convinced of just the opposite. So who do you listen to if you don't know the answer? The one who posts the most or the one who YELLS the most? If there are four answers and only one is right how would you know? What if they're all wrong? That's the problem with forums. You don't know who is right, who is wrong or even who anyone is. You get the most "rank" in a forum by posting the most responses and not for posting the most accurate responses. Keep that in mind when you feel compelled to believe someone simply because they have a bunch of stars under their made up forum name. If a member answers your question ask them to say why they think what they wrote. Hopefully there is some real information behind it and not just because "I heard it on another forum" or "some guy at a shop told me that".
    For any source of information ask yourself what the person has to lose if they lie or are wrong. If the answer is nothing or very little then they may not be putting much effort or truth into the advice they're giving you.
    Putting an idea is not bad, but guessing an idea is not correct, bakit mo sinabi na, walang set up na maganda pag mura ang budget mo? Meron, kase nasa installer yun, paano ka sasali sa EMMA kung V-12 at targa ang gamit mo, i don't know even if they pass in international standards of car audio, terminals pa lang nun, patay ka na e..
    Help the people to know basic, not to push them what somone know and start arguing right or not, let them know what is the right thing to start with and came up and say to us, "yeah your right".. peace..
    Aug 2010
    #229
    Hehe, huli. I apologize tsikotshop, I got carried away. Actually, I realized the mistake after re-reading the conversation flow but since hindi ko na ma-edit, hinayaan ko nalang as this is was a brief exchange of opinions. Again, I stand that go for good quality amps. Alpine 710 may seem good, but there are better ones out there with better built components (with a price too). You can reach a loud dB level over it, but economically, it wouldn't like that in the long run. Last thing I want is somebody being fooled again by the 4000W rating, doing 100+dB and then seeing the poor bloke shy away from car audio.
    Apr 2011
    #230
    Ayan na, going Loud n Clear na si sir Mouse nice to meet you kanina pare..
    Bro, sorry ngayon ku lang nakita to. Hehe. Thanks tol. Text text nalang :D
    #231
    Quote Originally Posted by tsikotshop View Post
    Forums
    True... Very True...
    Mar 2011
    #232
    hi guys,
    hanap ako ng chipipay amp to power a builtin sub for my car. nothing fancy basta mapaandar lng niya yung compact sub. nag palit kasi ako HU and hindi na gumagana yung sub.
    then nakita ko ito, V12 CAR AMPLIFIER Philippines - 3625946
    parang sa motor ata niya gagamitin, pwede ba sa car ito? ganyan lang ba talaga price niya? parang kasi too good to be true yung price.
  13. #233
    pwede po yan, basta 12 volts ang power supply input, kung gagamitin nyo sa sub, dapat siguro my lowpass filter yan or yung head unit nyo is my subwoofer output. alam ko, mas maraming ganyan sa raon, mas mga mura pa, just look around..
    Mar 2011
    #234
    Thanks Tsikotshop! KAilangan pala may low pass filter. Meron sub output yung HU kaso kakaiba saksakan parang square plug siya. Pag nakasaksak kasi yun, di gumagana ipod. Pero sa iba, gana cd,radio,usb. Kaya nakatanggal nalang siya para gumana yung ipod. Kaya hanap din ako ng amp para mapagana ko yung sub.
  15. #235
    kakaiba po yang unit nyo a, square plug para sa subwoofer output? anu pong head unit yan? A, pag wala po sub output and wala rin filter yung amp, pwede pa rin po magamit yan, gagamit po kayo ng separate low pass filter para sa sub nyo from amp, by these way, lahat po ng high pitches na papasuk galing sa source will be eliminated.
    Mar 2011
    #236
    Ah... Yan yung parang passive filter? dagdag gadget nnmn. Mas gusto ko maliit lang kahit mahina watts. Basta mapaandar lang nya sub.
    Flyaudio for forester. Plug and play lang siya kaya ganun yung sa sub out niya. Kaso yun nga, pag naka connect yung sub,di gumagana yung ipod. Pag naka tanggal nmn, gagana yung ipod kaso wala nmn sub. Sayang... Di pa perfect gawa.. un nlng prob..
  17. #237
    That is the problem, teka, meron po ba ibang low output yung head unit nyo maliban dun sa output ng sub? let say front output, pag meron po, ask nyo po muna yung nagbebenta nung amp kung meron low pass filter, sana meron para solve na yun problem nyo, pag wala, ang natitira nyong option is the passive filter, maliit lang naman ito, mga around 300pesos lang to sa raon and kasya mismo dun sa inclosure ng sub nyo, 2x2x4 lang ang dimension nun.
    Mar 2011
    #238
    thanks! thanks! i don't think meron siyang ibang sub out na line.. ang ibang nakikita kong rca is para sa aux, at yung tv para sa likod.. wala na ako makita iba pa.. sayang nga at dun pa nagkaprob.. may iilan din kami ganito prob.. may mga 2-3k na amp, hanap ako na may low pass filter.. wala ako time to go to raon.. malayo ako sa south kasi... hehe.
    May 2008
    #239
    mga sir mag tatanong lang ako ano po ba mas maganda na amp targa TA-805 or V12 710? and ok na ba yung HU ko Pioneer 1250 for tipid set up planning to have targa x652c seps and jbl gt-s12 sub, tapos meron na pala akong pioneer 6x9oval speakers anu po ba ma aadvice nyong gawin ko TIA
    Aug 2010
    #240
    I believe the key to any good sounding system is a good quality HU. As they say, sound quality is 90% tuning 10% installation. Given the right tuning, even a simple Targa separate would sound amazing.
audio set-up for beginners [continued]
