Results 541 to 550 of 1645
Tsikot Member Rank 3
- Jul 2004
- 1,540
August 8th, 2005 12:44 AM #541kotseaudioclub? Yup. Member din doon under the same username pero never pa ko nagpost. Nagbrowse lang ako sa forsale section. Nakakatakot kasi.
Mahal ba sobra ang DD? Kasi mura lang nung mga Kicker na S12 L5 or 7 mga 9 to 13k lang mga price ng 2nd hand may box or brand new. Problem ko hindi ko alam anong amp ang dapat gamitin na mura lang. Ipit kasi yung budget dahil talaga sa HU.
August 8th, 2005 12:50 AM #542
glntVR: Why not add JL to your list? Dami nag bebenta ng 2nd hand sa KAC for that price rance. It has both power and clarity that you want in a subwoofer. Believe me, masusuya ka rin pag puro bass heavy songs ang papakingan mo.
August 8th, 2005 12:51 AM #543
hehehe. ganyan din ako dati. sa advertised lang browse. punta ka sa system section din. maybe meron dun na the same situtation(optra with blaupunkt HU). who knows baka better pa yang HU mo. about the sub, i think very partial sila sa JL kasi pwede sa bayo at clarity(iwas upgrade) although i use Boston Pro. pero best is to attend EB para macompare mo yung mga gamit nila.HTH.
- Jul 2004
- 1,540
August 8th, 2005 12:56 AM #544Thank you sobra sa mga reply mga sir. I'll consider mga suggestions niyo. Sana by this week masimulan ko na ang pag bili ng mga stuff. Balikan ko na lang bukas ang thread na to.
August 8th, 2005 01:16 AM #546
- Jul 2004
- 1,540
August 8th, 2005 09:36 PM #547Sir Baurtwell nagbebenta ka ba ng DD subs? Anong model gamit mo and what amp gamit mo to power it?
- Feb 2005
- 22
August 9th, 2005 09:55 PM #548low sound output from the rear
need your expert opinions
i,m a newbie to sound setups so magtatanong lang po.What i want to achieve is clear sounds,for me to appreciate inside the car,a good bass and very fine treble. My present HU is a pioneer 8450, mbquart seps(216 discus series) front and rear. If i set the fader to 0 mahina lang sound na lumalabas sa rear if i adjust it to hear just the front speakers mas malakas and better ang quality ng sound. Is this normal, i have to adjust the fader to R6 just to appreciate the sound from the rear but the quality doesnt equal the front.
another question mga sirs. I have plans to put an amp and sub, kailangan ba hiwalay pa ang amps or pwede ba isa na lang para sa sub and seps? What would be compatible with my present HU and seps? anong brand ba masuggest nyo?
other plans - dvd player
pls consider the space i have. my car is a getz.
thanks!
August 10th, 2005 01:39 AM #549
Try disconnecting your rear seps and see if just having front speakers is enough. Puwede na ang 1 amp as long as it can power both sub and front speakers with enough power as required.
What's your budget for the sub and amps?
- Feb 2005
- 22
August 10th, 2005 08:41 AM #550wildthing,
thanks for the fast reply. malakas naman kung front seps lang, maganda rin quality ng sound if youre the driver pero kung rear passenger ka obvious na sa front lang yung sound.Less than 20,000 sana budget ko for amp and sub para meron pa pambili ng indash monitor and vcd changer.ano ba compatible na amp and sub sa present setup ko? Will my rear seps improve after i put an amp?
It may be variable speed I think. It's slowly being used on cars that either don't have an ICE, or...
A/c
