Page 25 of 83 FirstFirst ... 152122232425262728293575 ... LastLast
Results 481 to 500 of 1645
    May 2005
    #481
    sir wild ,,,thanks a lot
    #482
    its at pioneer center at shaw... lage :D
    Mar 2005
    #483
    yup.. tama si odell.. dun palagi yung eb every month... i'll be going this 18th..
    #484
    question lang ulit, i have a jensen cd4610 HU with a subwoofer output(1 RCA), 2 sets of RCA outputs to amp, pano ko ikakabit yung single subwoofer ko sa 1 rca? and pano ko gagamitan ng amp yung subwoofer withthis set-up?
    May 2004
    #485
    question lang mga sirs
    may pioneer deh 3550mp ako na nabili ko ng 2nd hand
    may changer also pioneer cdx fm687 na binebenta ask ko lang kng compatible ba ito sa hu ko?
    May 2004
    #486
    Quote Originally Posted by trup
    trup di ko yata gets. try ko kung tama, i presume you need a mono amp or kung ang 2 channel amp mo ay bridgable to mono(tama ba yung term?) para maiconnect mo sa single subwoofer. HTH.
    #487
    edwin, na gets mo naman, yung subwoofer out kse ng HU ko is 1 pc na rca lang, so kng walang amp di ba pwede? yung amp ko di ko sure kung bridgeable kse, may left and right channel na rca, pwede ba HU sub out to R ch input ng amp, then R ch out to sub ang gawin ko?
    May 2004
    #488
    ibig mo sabihin bale 3 pc ang rca mo(Left channel, Right channel and a mono RCA output, i think). Kung ganyan "baka" pwede y connector from your mono Subout RCA para maconnect mo sa L & R ng sub mo(assuming bridgable to mono). mas maganda siguro natin wait yung mga guru or ask it at KAC. wala pa kasi ako kita na single sub output(RCA) na HU and a single rca input na amp. btw, NY ka pa rin ba?
    Mar 2005
    #489
    ha.. tama ba yan?! 3 rca output sa HU!? medyo wrong ata ah. kung yung amp bridgable sana... hindi pwede na walang amp yung subwoofer
    Apr 2005
    #490
    hindi pwedeng walang amplifier ,kasi hindi tutunog ang sub,
    yung amp mong merong left and right rca input ,pwedeng ikabit sa right channel from HU sub output, suggsstion ko sa left channel mo ikabit .
    walang kang bang active crossover?
    #491
    Quote Originally Posted by niwde11
    manila na ko edwin, bali 1 set RCA for front, 1 set RCA for rear, and 1 pc RCA for sub, and 1 set for input pa....
    the 1st rca is the sub out, the 2nd set are the input RCA's, the 2 below ang pang front and rear channel....thanks sa tulong nyo ha..
    May 2004
    #492
    kung di ka naman gamit ng rear chanel yung na lang gamitin mo ma sub out(just like mine). pero kung may sub control ang HU mo try mo subukan yung 1 prc RCAsubout. bili ka nag y-connector to split the single rca papunta sa L+R input ng amp(btw, ano amp and sub mo?). i assume bridgable to mono ang amp mo kasi mono lang din ang signal mo. some say just connect your sub out to the left channel of your amp(di ka na bili nag y-connector). wala naman ako kita problema dito. HTH.
    Apr 2005
    #493
    pag nag y connector ka 2 signals (mono)papasok sa amp mo left and right input .pwede ka pang mag dadag ng isang sub. pwedeng rin kung brdgegable yung amp mo + left channel - right channel output to your sub
    Mar 2003
    #494
    http://www.bluespot.co.uk/stock_image/odsb8000a.jpg
    anyone own or heard of this subwoofer? not really into sounds. pang add lang ng bass. my car car audio is all stock. clarion HU gen 2.5 pajero yung ride.. it cost 10k,
    ODsb 8000A active sub main features:
    Active subwoofer with passive radiator technology in extremely compact enclosure
    The easiest way to more bass - amplifier and speaker in a box!
    Twin 200mm drive units using passive radiator technology
    Powerful 140Watt Class 'D' amplifier
    Efficiency 4 ohm
    Can accept line level (RCA) or speaker level input
    Max. acoustic pressure (SPL * 100Hz) 136dB
    Frequency response 60 - 120Hz
    Phase regulator (0-180 degree) adjuster
    Variable low-pass filter (60-120Hz)
    Gain controls (0.2V - 8.0V)
    Integral 20A blade fuse protection
    ISSAC and power indicator LEDs
    Dimensions 292w x 278h x 248d (mm). Weight 7.5kg
    Two year manufacturer's warranty
    Complete with fixing brackets, speaker level input lead, full fitting and operating guide
    Apr 2005
    #495
    Quote Originally Posted by PROMDIBOY
    Efficiency 4 ohm
    class D amplifier
    Mar 2003
    #496
    whats a class D amplifier? is it good or bad?
    Jan 2003
    #497
    acceptable. but then you'd probably have some problems with heat. But then it could be resolved with proper cooling.
    Apr 2005
    #498
    i cannot judge that( good or bad), but what i can say class A is the best
    Jan 2004
    #499
    Sound Guru's, How do I connect my ampli to my HU if my HU doesn't have a RCA pre out? Amp is V12 1507. Thanks!
    Apr 2005
    #500
    Quote Originally Posted by ching
    speaker output front channel
    connect to rca cord use white for left channel and red for right channel
    positive terminal is the inner part of the rca plug +(pointed head) ,outer part is the negative -(outer ring)
audio set-up for beginners (ARCHIVED)
