Page 24 of 83 FirstFirst ... 142021222324252627283474 ... LastLast
Results 461 to 480 of 1645
    Feb 2005
    #461
    question lang po. anu po purpose ng seps? iniisip ko kasi kung ako lang b na hindi na magpakabit ng seps, at subs lang ilalagay ko. stock na lahat.
    Mar 2005
    #462
    -aces_fan-
    actually ok lang yan. pero for listening pleasure kasi kung magpapalit ka. mas malinaw sya... yung mga drum beats maririnig mo ng mas malinaw...
    Feb 2005
    #463
    ah... e ang mga rear speakers po? ok lang din ba na stock yun?
  4. #464
    You can go with Coaxials.
    Jan 2004
    #465
    aces_fan: I actually started with stock speakers and a sub... Then separates a bit later to replace the fronts with separates. I disconnected the rear speakers. You can actually live without rearfills. Pero kung trip mong meron pa ring naririnig mula sa likod, ok na rin to have coaxials.
    Feb 2004
    #466
    for a beginning system, i would suggest you get a 4channel amp with built in crossovers, and get a 10 inch sub.
    use the front two channels to power your stock front speakers with your crossover set at about 70 or 80 hz. they connect your sub to the bridged rear channels of your amp with your crosoover set to 80hz or 70 hz and down. this will be sufficient. when you have money again, replace your front speakers with separates. when you have more money, you can invest in a dedicated subwoofer amp and another 10 inch sub, para pair na.
    dahan dahan lang. just make sure that the pieces you purchase can be integrated in your future system.
    Feb 2005
    #467
    thanks guys.
    #468
    curious lang....i dont know much about sound set-ups, how do you connect a single sub to a 2 channel amp???m parang series ba (Left(-) to right(+), then right(-) and left(+) to subs)
    May 2005
    #469
    ok ba yung seps na JBL??
    tsaka meron bang coax speakers na bilog? usually kasy 6x9 nakikita ko eh..
    tia!
    Jan 2004
    #470
    Quote Originally Posted by trup
    If the amp is bridgeable, you can connect the + of one channel and the - of the other channel into one sub. Whether it's bridgeable or not and what load it can handle is in the manual. If you don't have it, try searching google for it. HTH.
    Jan 2004
    #471
    Quote Originally Posted by izzy
    tia!
    There are as many circular coaxials as there are 6x9s.
    May 2005
    #472
    ok po ba maglagay ng two way coax sa front? or mas maganda talaga kung seps? SQ kasi habol ko eh...
    Jan 2004
    #473
    Kung maihaharap mo yung buong coax sa "sweet spot", that's ok. Pero kung naka tagilid lang sa pinto, di masyado, kasi dapat diretso papunta sa yo yung sound.
    May 2005
    #474
    oic.... thanks!
    what can you say about JBL and LANZAR? which of them are better?
    TIA!
    Jan 2004
    #475
    At ang laging sagot sa speaker face offs: listen to other setups with those brands and models installed, and say for your self what sounds good to YOU. Remember, ikaw ang dapat matutuwa sa naririnig mo hindi ibang tao.
    Jan 2003
    #476
    Quote Originally Posted by the_wildthing
    Tama! kelan next sound eb? parinig naman! set tayo ng maaga para lahat makapunta.
    Jan 2004
    #477
    KAC (www.kotseaudioclub.com) holds regular monthly EBs... Di pa ako nakakapunta... Parang ayaw ko nga baka biglang mag-upgrade ako sa ganda ng maririnig ko hehe.
    Apr 2005
    #478
    oic.... thanks!
    TIA!
    subs, baka u mean jl not jbl , what i know jl can be fitted in a smaller box than lanzar , with a certain frequency response (q) ,
    May 2005
    #479
    OT:
    sir wild
    any specific place the KAC boys hold their monthly EB ?...
    para makapag audition man lang
    thanks a lot
    Jan 2004
    #480
    Bro visit their site na lang, there's always a thread for monthly EB and it's sticky...
audio set-up for beginners (ARCHIVED)
