ah... e ang mga rear speakers po? ok lang din ba na stock yun?
You can go with Coaxials.ah... e ang mga rear speakers po? ok lang din ba na stock yun?
aces_fan: I actually started with stock speakers and a sub... Then separates a bit later to replace the fronts with separates. I disconnected the rear speakers. You can actually live without rearfills. Pero kung trip mong meron pa ring naririnig mula sa likod, ok na rin to have coaxials.
for a beginning system, i would suggest you get a 4channel amp with built in crossovers, and get a 10 inch sub.
use the front two channels to power your stock front speakers with your crossover set at about 70 or 80 hz. they connect your sub to the bridged rear channels of your amp with your crosoover set to 80hz or 70 hz and down. this will be sufficient. when you have money again, replace your front speakers with separates. when you have more money, you can invest in a dedicated subwoofer amp and another 10 inch sub, para pair na.
dahan dahan lang. just make sure that the pieces you purchase can be integrated in your future system.
curious lang....i dont know much about sound set-ups, how do you connect a single sub to a 2 channel amp???m parang series ba (Left(-) to right(+), then right(-) and left(+) to subs)
If the amp is bridgeable, you can connect the + of one channel and the - of the other channel into one sub. Whether it's bridgeable or not and what load it can handle is in the manual. If you don't have it, try searching google for it. HTH.Originally Posted by trup
ok ba yung seps na JBL??
tsaka meron bang coax speakers na bilog? usually kasy 6x9 nakikita ko eh..
tia!
There are as many circular coaxials as there are 6x9s.Originally Posted by izzy
ok po ba maglagay ng two way coax sa front? or mas maganda talaga kung seps? SQ kasi habol ko eh...![]()
Kung maihaharap mo yung buong coax sa "sweet spot", that's ok. Pero kung naka tagilid lang sa pinto, di masyado, kasi dapat diretso papunta sa yo yung sound.
oic.... thanks!
what can you say about JBL and LANZAR? which of them are better?
TIA!
subs, baka u mean jl not jbl , what i know jl can be fitted in a smaller box than lanzar , with a certain frequency response (q) ,Originally Posted by izzy
At ang laging sagot sa speaker face offs: listen to other setups with those brands and models installed, and say for your self what sounds good to YOU. Remember, ikaw ang dapat matutuwa sa naririnig mo hindi ibang tao.![]()
Originally Posted by the_wildthing
Tama! kelan next sound eb? parinig naman! set tayo ng maaga para lahat makapunta.![]()
KAC (www.kotseaudioclub.com) holds regular monthly EBs... Di pa ako nakakapunta... Parang ayaw ko nga baka biglang mag-upgrade ako sa ganda ng maririnig ko hehe.
OT:Originally Posted by the_wildthing
sir wild
any specific place the KAC boys hold their monthly EB ?...
para makapag audition man lang
thanks a lot
Bro visit their site na lang, there's always a thread for monthly EB and it's sticky...
