Page 9 of 15 FirstFirst ... 5678910111213 ... LastLast
Results 161 to 180 of 293
    #161
    Quote Originally Posted by carwhacko View Post
    Hindi ako natuloy boss kasi mahal eh may iba nagoffer ng cheaper na higher spec
    pwede bang malaman kung anong brand at anong shop?
    the latest growl specs is still inferior against your posted specs last year.
    Feb 2005
    #162
    Mas mura ata kay AutoLink..
    Sent from my CPH1609 using Tapatalk
    #163
    Quote Originally Posted by brodjason View Post
    bro, i'll be coming from the north. but will contact them still for price quotation. ty
    Sent from my SM-A710Y using Tapatalk
    Jan 2012
    #164
    Bought it with Toretto Hobbs for 26k with tv plus and back camera. You can PM them if meron sila for your unit.
    Jan 2012
    #165
    Yes another option is AutoLink kaso wala sila for my unit that time.
    #166
    both autolink and toretto-hobbs price is way lower than growl. just waiting for stock availability.
    #167
    Almost everyone else’s price is lower than growl. I bought mine at half the price of what growl is selling.
    #168
    meron 1gb ram android HU user dito? sobrang bagal ba pag sabay waze and music playback, and bluetooth connected sa mobile phone incase may tumawag. parang 3 task at a time
    thanks!
    May 2013
    #169
    thanks!
    Bro., are you referring to the 1gb ram and 16gb rom android head unit running 8.1? Interested din kasi ako diyan. Heheh. Less than 4k sa Shopee. Sulit for normal/simple tasking.
    #170
    Go for minimum 4GB RAM, 32GB ROM.
    #171
    Napatingin tuloy ako sa specs nung sakin. Hehehe
    Heres mine:
    2GB Ram / 16GB Rom
    #172
    Well, yours is OK na din if di ka naman multitasking sa HU. Still better than 1GB RAM/16GB ROM
    #173
    Quote Originally Posted by marky2115 View Post
    wala ganyan option sa stapon bro eh
    dont wanna spend more than 10k din hehehe
    Quote Originally Posted by bugoys View Post
    eto yun na order ko na ..
    https://www.lazada.com.ph/products/s...69739096.html?
    may mga napanood naman na akong youtube reviews sa generic android HUs, compared several specs 1gb vs 2gb, octa vs quad core etc. kung di naman multitasking, wala halos HIT sa performance sa lower spec'd models.
    #174
    ^ Just be prepared that the unit may not be a real Android 8.0 unit. Most generic Chinese head units are just on Android 4.4.2 or 4.4.4 and masquerading as higher versions. Other than that everything usually works fine.
    Medyo misleading nga lang yung title ng thread because what's being discussed here are Android head units that WILL NOT run Android Auto natively. You either need an additional dongle that enables AA and Carplay or use the screen mirroring app. You can, however, run Google Maps, Assistant and Music apps simultaneously in the background so parang AA na rin assuming your unit does not crash, overheat, run out of memory or suffer from defective NAND/eMMC issues.
    That's the problem. To simulate Android Auto functionality kailangan mag multi-task yung head unit so you will have several active apps running simultaneously. The 1GB units slow down real quick. Minimum memory config is 2GB if you want a usable experience.
    #175
    Quote Originally Posted by Woof View Post
    thanks for the heads up bro
    tanungin ko yun sa fb group nalang na nag recommend nyan kung ano mga downside ng unit
    btw yun mga nasa youtube, wala dongle na ginamit rekta lang with one of the two usb slot.
    sana at the least magawa nya yun waze, music playback (background music) and maayos mic for phonecalls
    #176
    Kung meron fit na HU sa rig mo mas maganda gamitin yung Dasaita na HU. They are using 4/32 gig config at Oreo. They are not cheap.
    #177
    na order na bro
    medyo limited budget, baka benta rin auto in 2-3 years [emoji16]
    #178
    sq is obviously inferior to my previous HU (x2550bt), noticeable at higher volume. 80% (of max tolerable of x2550 bt) or lower is fine though. surprisingly mic pickup seems at par with x2550bt, ill make sure to test again.
    might end up installing my RF amp and 12" sub
    #179
    How much for altis?
    The model same as urs
    #180
    Quote Originally Posted by istan View Post
    How much for altis?
    eto yun sakin ..
    2gb ram / 32gb rom
    https://www.lazada.com.ph/products/s...eAf2X&search=1
    ito yun cheaper alternative .. 1gb ram / 16gb rom
Android Auto Head unit
