both autolink and toretto-hobbs price is way lower than growl. just waiting for stock availability.
Sent from my SM-A710Y using Tapatalk
Almost everyone else’s price is lower than growl. I bought mine at half the price of what growl is selling.
meron 1gb ram android HU user dito? sobrang bagal ba pag sabay waze and music playback, and bluetooth connected sa mobile phone incase may tumawag. parang 3 task at a time
thanks!
Go for minimum 4GB RAM, 32GB ROM.
Napatingin tuloy ako sa specs nung sakin. Hehehe
Heres mine:
2GB Ram / 16GB Rom
Well, yours is OK na din if di ka naman multitasking sa HU. Still better than 1GB RAM/16GB ROM
wala ganyan option sa stapon bro eh
dont wanna spend more than 10k din hehehe
eto yun na order ko na ..
https://www.lazada.com.ph/products/s...69739096.html?
may mga napanood naman na akong youtube reviews sa generic android HUs, compared several specs 1gb vs 2gb, octa vs quad core etc. kung di naman multitasking, wala halos HIT sa performance sa lower spec'd models.
^ Just be prepared that the unit may not be a real Android 8.0 unit. Most generic Chinese head units are just on Android 4.4.2 or 4.4.4 and masquerading as higher versions. Other than that everything usually works fine.
Medyo misleading nga lang yung title ng thread because what's being discussed here are Android head units that WILL NOT run Android Auto natively. You either need an additional dongle that enables AA and Carplay or use the screen mirroring app. You can, however, run Google Maps, Assistant and Music apps simultaneously in the background so parang AA na rin assuming your unit does not crash, overheat, run out of memory or suffer from defective NAND/eMMC issues.
That's the problem. To simulate Android Auto functionality kailangan mag multi-task yung head unit so you will have several active apps running simultaneously. The 1GB units slow down real quick. Minimum memory config is 2GB if you want a usable experience.may mga napanood naman na akong youtube reviews sa generic android HUs, compared several specs 1gb vs 2gb, octa vs quad core etc. kung di naman multitasking, wala halos HIT sa performance sa lower spec'd models.
thanks for the heads up bro
tanungin ko yun sa fb group nalang na nag recommend nyan kung ano mga downside ng unit
btw yun mga nasa youtube, wala dongle na ginamit rekta lang with one of the two usb slot.
sana at the least magawa nya yun waze, music playback (background music) and maayos mic for phonecalls![]()
Kung meron fit na HU sa rig mo mas maganda gamitin yung Dasaita na HU. They are using 4/32 gig config at Oreo. They are not cheap.
sq is obviously inferior to my previous HU (x2550bt), noticeable at higher volume. 80% (of max tolerable of x2550 bt) or lower is fine though. surprisingly mic pickup seems at par with x2550bt, ill make sure to test again.
might end up installing my RF amp and 12" sub
How much for altis?
The model same as urs
eto yun sakin ..
2gb ram / 32gb rom
https://www.lazada.com.ph/products/s...eAf2X&search=1
ito yun cheaper alternative .. 1gb ram / 16gb rom
