Quote Originally Posted by xda2jojo View Post
Do not use carb cleaner, sisirain ang ibang parts dyan na hindi metal...
Dyan nasira ang PIAV ng lancer ko na injector na lalong nagcause ng erratic rpm.
Wala pong carburator ang avanza natin...so never use carb cleaner.
hanap lang kayo na pang throttle cleaner talaga, katulad nito.
Quote Originally Posted by werty View Post
Sir, Try mo palitan ng spark plugs, follow the standard tightening procedure for spark plug, then remove the throttle body from the intake manifold, clean the throttle body with carb cleaner. remove throttle sensor before applying carb cleaner.
* xda2jojo Sir, paki basa ulit yung post ko, wala pong nakalagay na carburator, nakalagay po ay throttle body...baka ma misled yung ibang makakabasa. Dont be offended nakakasira lang ang carb cleaner pag di alam kung pano gamitin.
