test
Page 1 of 5 12345 LastLast
Results 1 to 20 of 82
Thread: Avanza Wiring Diagram (By request)
  1. #1
    Join Date
    Nov 2007
    Default Avanza Wiring Diagram (By request)
    Power window wiring diagram for Avanza
    Pwede po pa request tapos post ko nalang dito ang diagrams.
    Ty
  2. #2
    Join Date
    Nov 2007
    Default Interior Light
    [SIZE=4]Interior Light
    [SIZE=2]Baka kailangan nyo to sa paginstall ng roof console.
    [/SIZE][/SIZE]
  3. #3
    Join Date
    Default Re: Avanza Wiring Diagram (By request)
    very helpful thread...
    sir request ako ng Stereo Wiring Diagram... TIA
  4. #4
    Join Date
    Nov 2007
    Default Avanza Audio wirings.
    Quote Originally Posted by mge View Post
    Just wondering sir.. para sa Toyota avanza lang neto. anyways here it is:
  5. #5
    Join Date
    Default Re: Avanza Audio wirings.
    sir thank you so much.. kelangan ko kasi nito para sa vanzy ng brother ko..
    by the way sir saan niyo nakukuha mga diagrams?
  6. #6
    Join Date
    sir how about the color coding for the stock stereo?
  7. #7
    Join Date
    Nov 2007
    Classifed po. ACP.
    Anong unit ba ng avanza sir? every model kase iba ang Player nya.
  8. #8
    Join Date
    1.3 Avanza J sir....
  9. #9
    Join Date
    Nov 2007
    Sorry sir wala e.. alamko yung sa owners manual kasama sa avanza, meron yan.
  10. #10
    Join Date
    hmmm... check ko na lang yung manual... thanks..
  11. #11
    Join Date
    Default Re: Interior Light
    Quote Originally Posted by Marfin View Post
    [/SIZE][/SIZE]
    kailangan ko nga
  12. #12
    Join Date
    sir, ni-check ko na owner's manual ng avanza, wala yung color coding for the wires of the stock head unit...
  13. #13
    Join Date
    Jun 2008
    double post
  14. #14
    Join Date
    Jun 2008
    * mge
    Typically sa car stereo, red-battery;yellow-acc.;black-ground;blue-power antena or amp. switch;then the 8 wires that are paired with a white stripe are for the speakers.
    Sa vanzy panasonic ang stock h.u. ng 1.3j, madali lng ma-distinguish yung mga wires, yung diagram nakadikit sa body ng car stereo, kaya kailangan mong tanggalin yung h.u. para ma basa mo yung daigram..
  15. #15
    Join Date
    thanks for the info sir...
  16. #16
    Join Date
    Feb 2005
    Actually madali lang naman ang wirings ng car stereo, lahat ng unit may mga diagram, meron sa HU mismo at meron din dun sa tag ang wirings nya then if bago yun HU meron din sa manual. Basta you know how to read and alam mo yun basic na red is for positive(+) black is (-) means grounding kaya't kaya kaya mo nayan. Even yun mga sa speakers,power antenna ay mga lavel or indcated sa diagram ng HU mo. HTH
  17. #17
    Join Date
    Feb 2005
    I want to share how I DIY my head console map light.
    • Test the map console light if it’s working before installing it. Please apply the basic wiring (red is for positive (+)) and (black is for negative (-)). If you can see there are wire in map console light (red), (black) and (yellow).
    1. Red (positive)
    2. Yellow (for door switch)
    3. Black (Negative or ground)
    • Try to fit the overhead console in the ceiling, if you can notice na walang metal holder toward dun sa aircon to hold, so you need to fabricate ng metal, any thin flat sheet will do.
    • Detached the dome light and unscrew the 2 screw to see the inner wiring of dome light, you will see 2 wire with color red and white blue (door switch)
    • Strip the red wire and soldier the red wire color from the console light
    • Strip the white blue and soldier the yellow color from the console light
    • Attached the black (-) wire to body ground or to the screw of the dome light that will definitely will grounded.
    • Wrap it with electrical tape to avoid short circuit of wires.
    • Assemble and put back in the proper place the dome light. Don’t forget to insert the thin flat metal of the console light in the dome light before tighten the screw. This will be the one to hold the console map light.
    • Try to open the door if the light in console dome if works, then test also the map light if its working
  18. #18
    Join Date
    Aug 2005
    I was able to get this sa net. I have it in PDF na. Any one interested?
  19. #19
    Join Date
    im interested sir... thanks...
  20. #20
    Join Date
    Aug 2005
    Pa PM na lang ang mga e-mails ng mga interesado. medyo malaki ang mga files.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
