test
Page 7 of 13 FirstFirst ... 34567891011 ... LastLast
Results 121 to 140 of 251
Thread: Avanza Engine Problem
  1. #121
    Join Date
    Sep 2005
    Default Re: Avanza Engine Problem
    Quote Originally Posted by nitro View Post
    Mga bossing good evening tanong ko lang if anybody experienced a problem na "rpm hunting" with their avanza? What happens is yung rpm mo is flactuating minsan mataas minsan mababa. I had my car checked ang sabi nila defective throttle body daw and they are charging me 22Kfor parts and labor. Any of you guys experienced this? Any info will be a great help Thanks in advance
    aw! sad to hear that sir, wala na sa warranty? kung wala na, try mo sa reliable auto shop like speedyfix or forcespeed. hth
  2. #122
    Join Date
    Sep 2005
    double post.
  3. #123
    Join Date
    May 2007
    Wow steelface great help to i've experienced the same thing casa told me na defective ang throttle body ko and is charging me 22k wow buti na lang nakita ko to thread mo thanks. When I asked them paano nasira kasi 56K Kms pa lang ako sabi nila wear and tear daw wow sabi ko di ako tumatakbo more than 1.5K/mo tsaka office-bahay lang wear and tear???? ha ha ha well pullout ko avanza ko tom and will try this first? Thanks a lot
  4. #124
    Join Date
    Jun 2008
    Sir, Try mo palitan ng spark plugs, follow the standard tightening procedure for spark plug, then remove the throttle body from the intake manifold, clean the throttle body with carb cleaner. remove throttle sensor before applying carb cleaner.
  5. #125
    Join Date
    ...double post...
  6. #126
    Join Date
    Do not use carb cleaner, sisirain ang ibang parts dyan na hindi metal...
    Dyan nasira ang PIAV ng lancer ko na injector na lalong nagcause ng erratic rpm.
    Wala pong carburator ang avanza natin...so never use carb cleaner.
    hanap lang kayo na pang throttle cleaner talaga, katulad nito.
  7. #127
    Join Date
    Quote Originally Posted by xda2jojo View Post
    teka how na ba ang car mo sir?
    anong car ba yan?
    avanza 1.3.at kelan ba dapat adjust ang valve toppet kasi napansin ko dina pino ang tunog nya...
    problema ko din back door ko dina nasara ng maayos nalagabong na pag sinara naka ilan adjust na sila same thing sa ibang door ko ganun din mas nag worst pa nun inadjust sa casa ano kaya maganda nito?
    then isa pa yun pag na apak ng clutch meron na ik ik na sound
    thx
  8. #128
    Join Date
    Quote Originally Posted by hans sebastian View Post
    thx
    may kulang tanong ko sir, how old na ang avanza mo?
  9. #129
    Join Date
    1 year old
  10. #130
    Join Date
    1 year old
    under warranty yan sir, pacheck sa casa
  11. #131
    Join Date
    any ideas what's causing the ik ik sound kapag apakan yung clutch? ganun din avanza namin (2007 1.5G) ngayon, seldom used lang kasi (2-3 days in a month). usually nawawala din yung ik ik sound after driving it for 1 day but after a long period of being idle balik naman si ik ik. ang source ng ik ik hindi sa clutch pedal assembly sa loob ng cabin, sa engine bay talaga i think sa loob ng hmmm clutch master ba tawag dyan? yung big black na bilog nakadikit sa firewall. possible kaya this is caused by using different brands of brake fluid (preston dot3 to stp dot3). pinaayos ko kasi yung brake ko months ago yung gamit ng shop pang refill stp dot 3 na brake fluid.
  12. #132
    Join Date
    Quote Originally Posted by mikibabs View Post
    try mo kaya bugahan ng konting penetrating oil dun sa pedal kung saan nagpla-play.....
  13. #133
    Join Date
    Jun 2008
    Quote Originally Posted by werty View Post
    * xda2jojo Sir, paki basa ulit yung post ko, wala pong nakalagay na carburator, nakalagay po ay throttle body...baka ma misled yung ibang makakabasa. Dont be offended nakakasira lang ang carb cleaner pag di alam kung pano gamitin.
  14. #134
    Join Date
    sir jaspi already done that, using wd-40 and silicon oil, tinanggal ko na yung cover under the steering column to check baka dun sa loob umiingay, sa labas talaga galing, end of the month paguwi ko ng bacolod will have my trusted mechanic check on it.
  15. #135
    Join Date
    hehehe....di ko sinabi na may sinabi ka.
    Majority of DIYers includes me and some mechanics don't know how to handle or use the carb cleaner,
    As per my experienced, more than 10years na ako nagbubutingting ng makina at computer box ng lancer(92, injector) ko, engot parin ako sa paggamit ng carb cleaner, doon ko nalaman noong nasira ang idle control valve embedded inside the throttle body(i don't know if our avanza mayroon ganyan), sa sirang yan ay nagmalfunction ang idle ko including cold start probs.
    so i don't recommend it using to our avanza na non carburetor type engine,
    or maybe to some expert, i experienced it, lesson to learned not to use it anymore.
    Maybe if you recommend it to use, please includes procedure.
    Ang mangyari kasi, once nasa kamay na natin ang carb cleaner na spray type.
    Yon spray doon at dito ang gagawin, noob ako, at wala sa procedure ng Can nakasulat, walang precaution or maybe they are(maker) assuming sa carburetor talaga gagamitin.
    Ayon sa isang iglap, goodbye TB.
    Binigay lang kasi yon sa bro ko ang carb cleaner na may lancer(carburetor type) din
    may nabili ako na pang Tb cleaner sa ace, plastic and rubber friendly.
    one example of using wd40,
    noisy door hinges, other replied, spray it with wd40.
    spray agad, damay ang door trim, tumulo sa ibang part, noob e, ayon deformed ang trim, sira ang pintura.
    sana includes naman ang proper handling para sa mga newbie.
    peace...
  16. #136
    Join Date
    Apr 2008
    bakit lagi nababasa air filter cover every car wash? ano kaya pwedeng gawin doon sa ilalim?
    pwede ba gamitin wilkin distilled water for tapping up GS battery?
  17. #137
    Join Date
    Quote Originally Posted by mick25 View Post
    normal lang yan sir, kahit sa ulan basa whole engine.
    kung worry ka baka papasok sa loob ng filter, normally may papasok talaga konti at di eto maiwasan pero may drain hole naman eto
    At di naman eto basta basta papasok sa throttle dahil sa filter.
    best thing to do, pagsabihan ang car wash boy na hwag itutok doon sa grills ang pressure hose.
    yes, pwede kahit absolute na distilled water, or any distilled water na available, pwede din rain water or tap water na overnight na galing sa ref, recommended morning ka maglagay dahil baba ang mga minerals nito, wag mo lang ibuhos lahat dahil useless din.
    same as pang top up sa coolant...
    And never use battery solution, para lang yan sa mga bagong batt na di pa nagamit.
  18. #138
    Join Date
  19. #139
    Join Date
    chrome.....
  20. #140
    Join Date
    Jun 2008
    chrome.....
    alam ko sir galit kayo sa chrome
Posting Permissions
  • You may not post replies
  • You may not edit your posts
