Results 51 to 60 of 251
Thread: Avanza Engine Problem
July 5th, 2010, 02:02 PM #51
Re: Avanza Engine Problem
July 5th, 2010, 02:34 PM #52
July 5th, 2010, 02:48 PM #53
- Aug 2008
- 51
July 5th, 2010, 02:58 PM #54
check the tensioner
July 5th, 2010, 03:28 PM #55
- Aug 2008
- 51
July 6th, 2010, 12:25 AM #56
yan yong mataas na bolt na nasa alternator,
check 1st the belt kung maluwag eto.
Kung di maluwag, could be any of this probs...
>>>baka akala mo lang na drive belt ang maingay, pero baka ang water pump na bos, pacheck mo nalang sa fav mech mo.
>>>pwede din ang battery, kumakarga palagi ang charging nito, mataas ang load ng alternator kaya nagslide ang drive belt, check mo na din kung medyo matagal na batts mo bos.
Kung sa tingin mo na wala pang sign na nag umpisang nag worn0out, ok pa yan.
According sa pms table ng tyt, every 5000km ang adjustment nito.Last edited by xda2jojo; July 6th, 2010 at 12:34 AM.
July 6th, 2010, 01:31 AM #57
- Jun 2006
- 254
July 6th, 2010, 01:37 AM #58
*xda2jojo
Thanks! pinalinis ko na ang servo tinangal po ito ng buo at binaklas.
after reinstalling nagfluctuate parin ang rpm, so i decided dalhin sa evangelista para ipareset ang ECU, hindi daw kasi marereset basta basta kung tatangalin lang ang battery. It cost me Php1,800 to reset the ECU using their OBD and they did some re-setting kung kinakailangan. Ok nman ang result tumino then after 30min of driving bumalik uli so binalik ko sa gumawa, what he did was check again the other solenoid sa bandang air cleaner, and now i think he got it na,so nagreset uli sya at smooth uli ang rpm. i will try to observe kung magloloko pa bukas.
July 6th, 2010, 01:39 AM #59
July 6th, 2010, 01:45 PM #60
* steelface001:
Yong OBD nya, dapat may lumabas na error code, para mas madaling ma-pinpoint kung saan or ano ang nadetect ng mga sensor na error.
Update mo lang kami bos kung ano na ang development...
PS: May pics ka ba sa ISC na natanggal including sa TB kung saan nakakabit ang ISC, bos?
pahabol...
you mean to say the MAF sensor?Last edited by xda2jojo; July 6th, 2010 at 01:51 PM.
Use stainless nuts... Amazon.com Sent from my SM-S901E using Tsikot Forums mobile app
Stud/Stad/Lug Nuts Corrosion
