hehehe....di ko sinabi na may sinabi ka.
Majority of DIYers includes me and some mechanics don't know how to handle or use the carb cleaner,
As per my experienced, more than 10years na ako nagbubutingting ng makina at computer box ng lancer(92, injector) ko, engot parin ako sa paggamit ng carb cleaner, doon ko nalaman noong nasira ang idle control valve embedded inside the throttle body(i don't know if our avanza mayroon ganyan), sa sirang yan ay nagmalfunction ang idle ko including cold start probs.
so i don't recommend it using to our avanza na non carburetor type engine,
or maybe to some expert, i experienced it, lesson to learned not to use it anymore.
Maybe if you recommend it to use, please includes procedure.
Ang mangyari kasi, once nasa kamay na natin ang carb cleaner na spray type.
Yon spray doon at dito ang gagawin, noob ako, at wala sa procedure ng Can nakasulat, walang precaution or maybe they are(maker) assuming sa carburetor talaga gagamitin.
Ayon sa isang iglap, goodbye TB.
Binigay lang kasi yon sa bro ko ang carb cleaner na may lancer(carburetor type) din
may nabili ako na pang Tb cleaner sa ace, plastic and rubber friendly.
one example of using wd40,
noisy door hinges, other replied, spray it with wd40.
spray agad, damay ang door trim, tumulo sa ibang part, noob e, ayon deformed ang trim, sira ang pintura.
sana includes naman ang proper handling para sa mga newbie.
peace...![]()
