Results 11 to 20 of 119
- Aug 2009
- 1,553
February 28th, 2010 05:25 PM #11*ArrJay0712: With the kerosene, what i do is, i put it on a chemical resistant spray bottle and spray the affected area's and let it sit for about 3 minutes and then wipe it off with a clean MF towel dedicated for kerosene. Don't use spray bottles intended for water, the kerosene would just damage the nozzle. With regards to how much you apply, just enough to soak the portion and completely cover the paint, after every minute you could go over and treat those portions that are heavy with asphalt.
- Nov 2008
- 20
March 1st, 2010 10:30 AM #12you've always been very helpful in sharing your expertise. Thanks Madkatz
- Sep 2009
- 35
March 1st, 2010 11:01 AM #13You're right nelz.. Big thanks to ma'am madkatz!
Btw, madkatz where did you buy the kerosene & the spray bottle?
March 1st, 2010 11:07 AM #14
I can do full detailing on my car using my pcxp but to make llife simpler:
1. Go to Bigberts and undergo paint protection
2. Weekly wash and wax at home. ^_^
- Aug 2009
- 1,553
March 2nd, 2010 02:07 AM #15*ArrJay0712: kerosene from any gas station that carries it, as for the chemical resistant spray bottle, you can find it at chemical stores.
- Sep 2009
- 35
March 3rd, 2010 10:55 AM #16I have another question (sorry if I ask too many questions
After using Mothers scratch remover, do I have to do anything? Which is better to apply after, instant detailer or spray wax or none at all?
Thanks again!
March 3rd, 2010 03:49 PM #17
hi, you can clean the area with joy (dishwashing liquid) and water, to remove all traces of scratch remover residue. wipe to dry, then re apply wax.
hope this helps.
- Sep 2009
- 35
March 3rd, 2010 05:46 PM #19
pwede cguro...
if you'll try mothers products (sya palang nasusubukan ko, probably meguires someday), you can start with cleaner wax, then sealer and glaze, then pure carnauba wax. or mas mabilis - cleaner wax first, then spray wax. una un cleaner wax, to remove first any scratch remover residue...
my case, noon wala pa ako cleaner wax, joy dishwashing liquid lang pang alis ko nang scratch remover residue... tutal madalang lang gamitin un scratch remover and small area lang un huhugasan with joy and water...
- Sep 2009
- 35
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
