D3 Technologies - Home | Facebook
Sent from my ASUS_Z010D using Tapatalk
Done my shopping at Ginnovas, replenished my stocks....thanks Ginnova. KAIO, optimum poli-seal (tried it, was able to remove marring by the clay sponge, so its a good replacement for KAIO), collinite 476 and clay sponge. Next target, gtechniq crystal serum light.
Every ilang weeks or months ka po nag rere apply sir? At do you need to remove the old wax before mag re apply?
Sent from my SM-N920S using Tsikot Forums mobile app
Nag Carwash session ako nag ulit ako ng wax at sinubukan ko si Collinite 845. Before waxing nag claying muna ako the Meg's Ultimate Polish then Collinite 845. The next day pinatungan ko naman ng Meg's Ultimate Finish. Grabe ang water beading di man lang halatang naulanan kotse ko. Pero before the Ultimate Finish pansin ko di ganun ka kintab si Collinite vs sa gamit ko na NXT. Sinubukan ko kasi si Collinite because mas durable "daw" so let's see.
Tanong ko rin kung nakakahide rin ba ng swirls si Collinite 845? Si NXT kasi nakakahide ng swirls at light scratches.
nice haul sir. glad to know may small bottle pala ng KAIO si sir ginnova.
i don't based sa weeks o months eh, when i see na medyo dull na kintab o kaya kapag sinisipag kahit every after wash pwede naman. hindi na, kung may old wax man manipis na lang. pero madali naman if you want to remove, tapangan mo yung shampoo o kaya punasan mo ng IPA (isopropyl alcohol) diluted 50/50 sa water bago ka mag-wax.
no idea kung may filling properties ang 845. but since meron ka na po so all you need to do is try it. you can apply in one panel yung 845 then NXT sa kabila then compare
Ang 915 ba paps merong filling properties?
Yup, if you want to experiment just apply different product combo in each panel.
Based on my experience may filling properties yung 845. I used it to hide light scratvhes on my black suv
Sent from my SM-A700FD using Tsikot Forums mobile app
Sharing some photos of the Dual Action Polisher Pro v2.
Unit is supplied with 220V plug so there is no need to use 220V/110V step-down transformer unlike the machines from USA. Unit has full CE/GS certification. The Dual Action Polisher Pro v2 offers all the features of the more the expensive machines at an affordable price.
What's inside the box: 1x DA Polisher Pro v2, 1x 5" Backing Plate, 1x Handle, 1x Foam pad, 1x Wool pad, 1x Wrench, 2x Carbon Brush, 1x User Manual.
The 6-speed selection knob on top allows you to select speed on the fly from 1800-7000 OPM. With a powerful 800W rated motor (1200W peak), it is possible to remove scratches and swirl marks. It is also perfect for applying glazes, sealants and waxes.
The large power trigger switch allows you to turn on/off the machine instantly. Built-in electronic soft start function protects the equipment, the user and the car's paint. The machine spins slowly at start, then speeds up to your target speed level.
The power lock button on the handle can be used to keep the machine running so you do not need to keep pressing the trigger switch. Simply press the round button to lock the machine. Press the trigger switch anytime to release the lock mechanism.
The ergonomic design allows for precise paint correction with complete comfort, including curved surfaces and difficult to reach areas. The handle can easily be placed on left or right side depending on the preference of the user.
Dual action polishers are very popular with car enthusiasts and professionals alike as they are low risk (will not harm the car's paint) but gives much better results than polishing by hand. In other words, the machine is idiot-proof.
Yes, very good price. I had compared with other stores. A comparable model costs around P15,000 plus. So this is basically half the price. Other models are P25,000 plus and are 110V so would require step-down transformers.
DA Polisher Pro v2. What makes it affordable is because it is OEM. This means you get the same quality as the more expensive brands (Rupes, Meguiar's, Griot's Garage, etc.) but do not pay for the brand name.
Help po. Ngayon ko lang napansin sa kotse ko, pero duda ko sa gasoline station galing, bandang gas tank kasi.
Kahapon ako nag pa gas, pero ngayon ko lang nacheck.
