Like this one po? Kakawax ko lang kac 2 days ago. Tapos pag ginamit ko ba to, matatangal amg wax?
Ok got your point. You can purchase probably a lance similar to the pressure washer you have right now. Regarding the free soap gun lance attachement. I have read somewhere you can make it foamy by putting 80%soap and 20% warm water, shake it to produce bubbles before using it. I have not tried it yet but I will soon.
why would a detailer remove wax? hindi naman wax cleaner yan...
you can read meguiars detailing guide. you will find where quick detailers are in the chain. there are so many guides out there. autoglym guide. mothers' also has a guide.
quick detailer as the name implies is for quick fix to maintain the gloss. hindi matatanggal ang wax....
kung interested ka sa makapal na foam, check out chemical guys phils kung may mabili ka nung mga super suds at snow foam shampoo nila. i bought from them their regular citrus wash and gloss shampoo ok din naman ang foaming sa nilfisk washer ko. i use it only prior to my periodic polishing schedule kasi mahalfor regular wash, i use microtex shampoo, good value for me. btw, wala sa kapal ng foam ng shampoo yan, importante yung cleaning properties niya saka slickness sa paint surface para ma minimize ang swirls at marring during washing.
^ sir thank you sa advice.next question ko po. Pano kaya to tanggalin?
done doing the clay bar step + QD pero hirap pa rin matanggal e
looked like ashpalt tar to me, dumaan ka ba sa bagong aspalto na kalsada? di talaga kaya ng claying yan lalo na kung dry at tumigas na.
try mo wd40, spray mo sa isang spot muna, let it linger for a while then wipe it with microfiber cloth with wd40 din. if lumambot at kaya matanggal, continue the same process, if kaya ng kuko mo to scrape it, pagtyagaan mo. kung di kaya ng wd40, subukan mo kerosene. gamit ka ng spray bottle, then same process. try mo sa isang spot muna, let it soak then wipe.
then after, wash your car thoroughly para maalis ang wd40 o kerosene...HTH
If this is asphalt, +1 sa kerosene. The guys at my suki carwash used this--they said they were seeing a lot of these marks on their customers since the main road nearby had just undergone roadwork. Just wax your car after since kerosene will remove the previous layer of wax or sealant.
Aspalto.
Kerosene will do.
Sir Monty, bat di ka mag tayo ng detailing/ car wash shop saten? Endorse kita sa jazz club solid north group[emoji4] marame-rame din yun.
Thank you so much sir monty, sir kai s and sir makyong. I will try it with koresene this weekend. I will post the result. Thanks again [emoji4]
And oh, yes sir monty dumaan ako sa bagong aspalto. Dami kasing road renovations dto sa province e (ilocos region)
Any recommended car cover that is water repellant and doesn't cause too much scratch on the paint?
Thanks!
