Page 292 of 392 FirstFirst ... 192242282288289290291292293294295296302342 ... LastLast
Results 5,821 to 5,840 of 7833
    #5821
    Quote Originally Posted by kai s. View Post
    ^ saan ka sir nakabili ng Rupes dito? Di ko kasi mahanap dito yung mga favorite na brand ng DA polisher na parating binabanggit sa mga detailing sites.
    PM me if interested. I have the widest selection of DA polishers and accessories.
    Aug 2012
    #5822
    Quote Originally Posted by flakez View Post
    Planning to buy a nanoskin autoscrub. May grade pa pala yun. Hehe. Ano suggested niyo na bilin ko? Iniisip ko medium grade para gitna. Hehe.
    Sent from my Flare_S4_Plus using Tapatalk
    Fine grade ang gamit ko. P600 lang.
    Sent from my D5833 using Tapatalk
    Jul 2015
    #5823
    Quote Originally Posted by jkatzify View Post
    Dahil sa bigat ng rupes- halos medium pressure lang gamit ko- same hand speed as used for M105/ Speed during heavy correction is 5-6. Passes made on panel is 4-5 until it flashes. Pad priming (KB method).
    Anything wrong with the process?
    Thank you
    I haven't really tried CG compounds, I still prefer Megs, Menz and Scholls (expensive).
    It seems that v32 is using the same technology, micro abrasives, if this is the case and if your using the same process for both products and you get more cut from 105, it just tells that 105 is better in terms of cutting power. Although you can also achieve the same results w/ v32 by changing pads, mf pads, apply a but more pressure but still maintaining consistent rotation of the pad, and do slower arm speeds. Usually i go up to speed 5 with rupes in the first 2 passes, then go down to 4 in the last 2-3 passes, if i am working on heavier paint defects.
    Also consider the size of the panel your working on, dont go 2ft x 2ft if paint defect is heavy, 1-1.5 sq ft will be enough.
    Hope this helps. Happy polishing!
    Sep 2009
    #5824
    Quote Originally Posted by Kitoy22 View Post
    Thank you for the inputs Kitoy22.
    I'll try the smaller polishing area-combination of speed 5 and 4- and MF pads.
    Kakahinayang din kasi kung di masusulit yung V32.
    Jul 2015
    #5825
    Oo nga sayang, tapos hindi pa sya dusty, update us bro, after doing your adjustments, and pics pls. Hehe.
    Aug 2012
    #5826
    *ginnova: Meron ka na ba DA polisher na same spec to new Meguair's MT300?
    #5827
    Quote Originally Posted by red_one View Post
    This is what i have. Similar to Rupes Bigfoot LHR15 and LHR21.
    Aug 2012
    #5828
    Quote Originally Posted by Ginnova View Post
    How much ang ganyan bro? China or Taiwan made?
    Nov 2007
    #5829
    Hi, saan kayo bumibili ng Collinite #476 9oz
    may nabili ako sa Sky High Agrivet Store caloocan 850 9oz original naman siguro to noh?
    Dec 2004
    #5830
    Quote Originally Posted by d_9 View Post
    Got mine from them as well. Looks legit based on the results I have so far - two months in this rainy weather and still beading well.
    Nov 2007
    #5831
    Quote Originally Posted by corbon44 View Post
    Nice! Thank you sir, I was still wondering if it is legit. Since its my first time using this product
    Aug 2010
    #5832
    Some new goodies just arrived! As well as a pads refill.
    Also, shout out to Ginnova for accommodating my inquiries about his products. I originally planned to purchased them locally but I changed my mind and sinabay ko nalang sa laptop shipment ko
    May 2015
    #5833
    ka-tsikot! Magandang umaga
    May alam ba kayong remedy to remove watermarks? Sa paint po ng sasakyan. If meron saan nakakabili at magkano? TIA!
    #5834
    Quote Originally Posted by johann123 View Post
    usually nawawala yan sa ilang carwash lang
    minsan naman wax lang
    minsan polish
    worst case rubbing compound
    ako ngayon, car wash agad pag may putik maski umuulan; wag lang tumigas yung naiwang putik/watermarks.
    Apr 2012
    #5835
    Quote Originally Posted by jhnkvn View Post
    nice haul sir...
    Jun 2016
    #5836
    minsan polish
    paano po sir tatanggalin ang water spots sa chrome? kahit kutkutin ayaw po matanggal
    Jul 2015
    #5837
    Quote Originally Posted by jmusicalis View Post
    Chrome polish po sir
    Jun 2015
    #5838
    Use vinegar
    Dec 2014
    #5839
    Dami ah. Hehehe. Matagal-tagal maubos yan
    Jun 2016
    #5840
    Quote Originally Posted by Sebastian Bach View Post
    Use vinegar
    may dilution ratio po ba sa vinegar? at ano pong klaseng vinegar ang pwede? thanks
    ahh..parang nakakita ako nyan sa true value..mothers ata. thanks sir! try ko rin muna vinegar kung gagana
"Tamang OC lang" - a newbie's guide to car appearance maintenance
