Page 251 of 392 FirstFirst ... 151201241247248249250251252253254255261301351 ... LastLast
Results 5,001 to 5,020 of 7833
    #5001
    Quote Originally Posted by shok View Post
    May nakasubok na ba ng Autosol Professional Compound?
    I plan to use it after wet sanding a panel using #2000 sand paper.
    I tried sanding a test spot then compound with Megs UC, may mga sanding marks na natira after 2 passes.
    UC should be able to remove 2K grit with the right pad. M105 should be able to remove 2K easily
    Here's my demo panel sanded with 1.5K unigrit sanding disk and polished with M105/MF pad combo.
    Jul 2015
    #5002
    May machine kang gamit? And ano itsura nung natira na sanding markings? few deep marks?
    Try to look for a 2500 grit or 3000 kung may makita ka, sand mo ulit yung my natira, saka mo gamitan ulit ng Megs UC.
    #5003
    Quote Originally Posted by Ginnova View Post
    Quote Originally Posted by Kitoy22 View Post
    Drill attachment lang na DA ng Megs using the supplied Megs maroon compound pad. Tipid mode and generally used for touch ups lang.
    Yup. Few deep sanding marks lang. But generally makintab naman.
    San makakakita ng #3000 or #5000? Wala sa mall hardwares. Sa mga auto paint shop meron kaya sila?
    #5004
    Most off the shelf sand paper are not unigrit which causes non-uniform sanding marks. make sure ibabad sa tubig with soap sanding pad for several minutes before using them.
    i have 3000 3in sanding disk but if u have deep sanding marks di rin nya kaya tangalin.
    #5005
    #5006
    Thanks sa tip Jhong! Di ko nga naibabad yung sand paper before sanding.
    Ibababad ko muna before ko ituloy sa weekend. Yung tirang sanding marks hindi naman makapa sa daliri. Pag may certain angle lang ng ilaw nakikita. Itry ko pasadahan ulit ng light sanding yung mga spots na meron.
    Nov 2014
    #5007
    I mainly use 5in backing plates for my polishers ( rotary and DA ) for general polishing. Easier to control and fits most panels. Ano polisher mo. Send me a pm if you need one. I have variety of sizes from 1in to 6in.
    Sir can you pm me sa price ng 5in cutting pad tsaka pang finish na pad.or your number para makapag tanong na ng maigi regarding rotary pads.[emoji16]TIA
    #5008
    Quote Originally Posted by tahxcool View Post
    Attachment 29741 time to hoard!
    Ang dami sa True Value Shangrila, TW Lquid Spray!
    Buy one take din yung Eagle One products; e.g. Nanowax!
    #5009
    Sanded part and unsanded. Pasensya na maalikabok.
    #5010
    For heavy waterspots , acid based cleaners are very effective. I use industrial grade waterspot removers for these kinds of waterspots.
    waterspot
    Ano ba ang dahilan bakit nagkakaroon ng waterspots; just wondering?
    Apr 2012
    #5011
    ang dahilan yun mga minerals na kasama sa tubig kapag natuyo nagiging waterspots. like kapag nag-washing ka at di mo pinunasan, maging watermarks. pinakaworst yung acid rain or kapag naambonan at natuyo sa araw, kapag di mo agad natanggal mag-etched na sa pintura.
    maraming mababasa kay google about waterspots...
    3 - Types of Water Spots - Type I, Type II and Type III - Auto Geek Online Auto Detailing Forum
    #5012
    Thanks bro sa info, as usual very helpful!
    Apr 2012
    #5013
    you're welcome bro. para maiwasan magka-waterspots or watermarks, maintain na naka-sealant or wax yung paint surface mo. hindi rin madaling kumapit ang dumi at mas madaling hugasan kapag nakasealant or wax.
    Oct 2015
    #5014
    2015 na kasi, applicable pa ba tong post mo for new cars or may mga brands na ngayon lumabas na mas okay? haha balak ko kasi gawin lahat ng sinabi mo dito. Salamat boss
    Apr 2012
    #5015
    Quote Originally Posted by Leimaymay View Post
    applicable pa naman ang sealant at wax till now most if not all of the detailing shops around the globe still use them. if you want new trend sa paint protection, go for nano coatings or glass coatings.
    Jul 2015
    #5016
    Its really hard to see bro, mag kaiba focus nung dalawang pictures. The one on the right shows more crisp reflection despite being sanded. Medyo misleading. Try to put a coin or tape dun sa surface then try mo dun direct yung auto focus. Or do manual focus kng kaya.
    #5017
    Ok bro I'll do that. The sanded part is also coumpounded but hindi mafocus yung sanding marks. It improved a lot prior to sanding but the sanding marks....Ipapacompound ko na lang ito sa detailer pag hindi ko pa nakuha sa susunod but I really want to DIY with the tools and polishes that I have.
    Oct 2015
    #5018
    May polisher po ba na 12volts na pwede sasak sa outlet ng sasakyan? San kaya nakaka bili. Malayo kasi parking sa outlet.
    Jun 2004
    #5019
    Umulan din. Wehehe.
    Apr 2012
    #5020
    Quote Originally Posted by dishcom View Post
    simple lang naman solusyon, gawa ka ng extension cord mo
"Tamang OC lang" - a newbie's guide to car appearance maintenance
