Mga sir, please I like to have your opinion kung justifiable ba talaga yung paint protection ng nano coatings or glass coatings pricewise vis a vis which is being done and promoted in this thread DIY tamang OC?
Wala pa kasi akong nakita.
* khenma0928
sa SM mega ako nakabili, meron din nyan sa Blades
Alin po ba ang mas okay gamitin? 3M towel or Microtex products? Alin talaga ang hindi nkaka scratch sa light pressure..
I bought 3M auto scratch remover.. Any reviews from 3M detailing Products?
Thanks bro for your info!
Sir CLAVEL3699 POMPONAZZI Glass Coating Protection, claims will last more than 5 years!
If this works as promise then, who needs to do "tamang oc"!
I hope sir kitoy and ginnova can shed some more light!
*Sir vunrem,
Anong technolgy yung glass coating nyo and how much and where ninyo ipinagawa?
welcome!
they have actually posted before about their reviews, nasa back pages.
glass coatings will definitely last longer but it does not mean once you apply it yun na, you still have to periodically maintain and replenish it.
beside glass coatings, check out also superhydrophobic coatings like ultra ever dry, maybe you get even more amazed...
car wrapping is also another option if you want to preserve and protect your car paint.
the old school "tamang oc" and "pahid wax" i guess will still remain. iba pa rin feeling kapag nahihimas mo sasakyan mo![]()
Eto yung post ni sir CLAVEL3699 dyan sa baba in case you have missed it:
Glass Coating Paint Protection:
WORLD'S FIRST REAL QUARTZ-MELTING COATING SYSTEM, POMPONAZZI-
It Protects
POMPONAZZI Glass Coating Protection utilizes the latest Nano -Technology in paint protection for your vehicle. With our paint protection service your car will be totally protected from damaging environmental elements such as:
UV Rays
Bird Droppings
Tree Sap
Road Dirt and Grime
Acid Rain
Detergents
Silicone Spray
It Shines
POMPONAZZI RQMC(Real Quartz Melting Coating) Protection provides the ultimate mirror finish protective coating which remains flexible and allows the paint surface to remain natural and flex with temperature changes.
It does this because it contains:
No Wax
No Silicone
No Teflon
No Polymers
It Doesn't Wash Off
POMPONAZZI RQMC(Real Quartz Melting Coating) Protection uses products made from world's first real quartz melting - Liquid Glass, which adheres to the paint and provides a chemical bond. It will not wash off, crack or peel and will continue to perform it's function for a guaranteed 5 year period or lifetime under a maintenance plan.
POMPONAZZI RQMC(Real Quartz Melting Coating) Protection provides the following benefits:
Protects & Enhances New Car Shine
Makes Washing Easy
Eliminates Waxing & Polishing
No Polymers
Preserves Resale Value of New Car
Increases Resale Value of Used Car
More accurate colour matching for touch ups and panel work
Re: POMPONAZZI. I had proof-read these entries from another site:
but... this company, makes toothpaste and such, which is.. shocking
and.. they claim, they are the first with a sealant which turn's in to quartz, which i don't think it's true.
GTechniq's C1 is also a sealant, which turns partly into quartz crystalRegarding the glass effect, if you notice all paint are orange peel free. If you apply an LSP like Z2 or so on an orange peel free paint, you (automatically) get a mirror finish.Erm! Looks a bit snake oil, to obtain that kind of shine you need (apart from the obligatory black car) extremely defect free paintwork.Pomponazzi ! - Detailing WorldPomponazzi is silica dioxide treatment. The idea is good, but the product is not stable at all! Application is very tricky and can harm the body paint which only compounding can remove. And when it does work, it doesn't last really more then 6 months.
It's two liquid mixture and need to use in 1 hour. The bottle itself if kept more then 2 months, will explode! BE CAREFUL! I have video to prove it if anyone interested.
There are a lot of coatings available in the market. Parang kabute na nagsulputan. most are repacked and relabeled. there are legit and innovators of coatings. some are pretenders. Some coating claims are unbelievable/exaggerated.
Based from experience here are my thoughts.
- most coatings will definitely outlast any wax or sealants. coatings can last for years ( some will last less than a year ) depending on the coating and how you maintain your car. kung sawa ka na sa kaka-apply ng wax at sealant ( multiple layers pa ) and you do not have the luxury of time doing weekly/monthly/bi-montly wax/sealant application coating is the route to go.
- most are chemical resistant and to some extent acid resistant.
- most coating adds a significant layer to your paint ( 1um-2um per layer ) compared to a wax/sealant.
- some coating forms a layer of clear coat ( resin/ polymer based )over car surface and most are silica based ( glass coating )
- most coating wil provide better mar resistance and to some extent scratch resistance. pls note that all coatings will get scratched. no such thing as scratch proof.
- sa looks department, most coating will provide a very reflective/mirror like look but it will largely depend on how the paint was prep.
anyway , read reviews of the coatings before using them. if a coating is good as advertised , it will be extensively sold/distributed/used world wide.
blacklight and v7 ba mam cathy? both give good result and smells good too...![]()
Dumating na new tools ko.. 5" Hex-Logic Polishing/Buffing Drill Kit.
So far yes, its worth it, less maintenance, just wash regularly, less swirls, and keeps my ride cleaner longer, basta umulan, malinis naulit sasakyan ko.
This is a 1 year old coating, still beads and sheets water very well, just removed, asphalt and water marks at tge middle of the year.
Oops baliktad, pano ayusin to mga bro? Thanks!
Thanks to all for the info about Car Glass Coating!
So far anong brand e.g. Pomponazzi, Endo System, etc., yung subok na according to your experiences and feedback?![]()
