Results 6,761 to 6,770 of 7834
August 20th, 2018 12:05 AM #6761
Buset 5 mins into the garage umulan pa ng malakas.
Sayang nanaman car wash haist.
Ako hinahayaan ko lang matuyo kesa punasan magagasgas lang.
Binabawi ko na lang ng cleaner wax pag ngayong tag ulan mas madalas.
Pero yung windows pag hindi tinatamad pinupunasan ko ng microfiber then dry with chamois. Pati headlights na din.
Di rin naman kase feasible na i rinse lagi after rain. Lalo na pag papark mo sa mall or office hehe.
- Jan 2008
- 8
August 20th, 2018 12:54 AM #6762Masisira po ba paint pag air dry ang pagapapatuyo ng sasakyan kahit nakahydrophobic wax ito? air dry lang po kasi ang pagpapatuyo ko after maulanan nung sasakyan.
- Aug 2018
- 4
August 20th, 2018 01:00 AM #6763Based on my experience hindi naman
- Mar 2005
- 703
August 25th, 2018 09:19 AM #6765
I have the same one. Ok naman. I guess i have to find a soap na produces thick foam para makapit sa car.
- Feb 2010
- 227
August 25th, 2018 05:18 PM #6766
August 27th, 2018 03:06 AM #6767
Bought it on shopee. I just use ordinary microtex shampoo. it foams okay but not thick enough though.
Probably would buy a legit snow foam lance para mas okay ung pag produce ng foam and then a branded shampoo.
Jusr finished compounding the car today. Not perfect though. Need a better combo than megs ultimate compound and mf pad. Probably megs m105 and mf pad/cutting pad.
Tomorrows project: polishing using m205 naman.
August 27th, 2018 03:22 AM #6768
kahit di masyadong magfoam bro basta ok ang lubricity. if you want it foamy, yung mga super suds ng Chemical Guys maganda. kaso wala na yata distributor ng CG products diyan sa atin, you can buy online though.
i think it will turn okay yang na-compound mo once you do finishing with M205. fo me, as long as mawala yung swirls at watermarks ok na, any scratches na maiwan hindi ko na alintana, malalim na yun. kapag hinabol pa, tendency lalong ninipis clear coat.
August 27th, 2018 05:54 AM #6769
Yes kasi adjusted na nila yun binayaran mo initially to reflect yun correct plate ending mo, that's...
1st LTO renewal after 3 yr registration
