Page 102 of 127 FirstFirst ... 252929899100101102103104105106112 ... LastLast
Results 2,021 to 2,040 of 2535
    #2021
    Guys starting pa lang ako sa detailing. Sobrang daming back read hehehehe.
    I have a silver 2014 vios. By hand lang ako at eto ang mga gamit ko for now. Microtex Car Shampoo, Formula 1 Premium Paste Wax, NanoSliq and Glass Science Glass Scrub.
    Next project would be to have the car clay barred. I'm debating buying my own or just have the detailer do it. From my list any pros and cons and ano pwede ko idagdag para sa complete protection?
    Follow up question. Pwede ko ba gamitin yung formula 1 premium paste wax as sealer sa windshield kahit sabi sa details niya na hindi daw pwede? Pwede kasi siya sa headlights eh so i figured baka pwede din sa windshield?
    Pasensya na sa mga noobie na tanong Salamat
    Jul 2015
    #2022
    If the cost of the clay bar kit is acceptable sayo sir, I think mas ok na bumili ka, since long term investment nman to.
    Ayus yan glass science scrub. Use a wet sponge to utilize it properly. Use it lng if water spots cant be removed with regular wash. Otherwise dont use it. Im using bottled water as washer fluid now so ive stopped using glass science scrub.
    You can try sa second row glass yan wax. If you can buff it to clear clarity then wax away your windshield. Buffing windshields will cause glass to collect dust much faster. After buffing use cold distilled water with mf to neutralize the static. Just wet and dry. Avoid buffing. Thats my rain prep.
    #2024
    Quote Originally Posted by Kitoy22 View Post
    Thanks Kitoy22. I think mas may fear ako na baka maging mali ang application ko ng clay bar kaya hindi ko pa siya binibili. Dami ko na pinanood sa youtube pero parang gusto ko pa rin makitang gawin muna ng iba at saka ko gagayahin hehehehe.
    #2025
    I will try that! Salamat
    Wag mo lng ihulog hahaha
    Quote Originally Posted by RM Hobbyist View Post
    Your new theme song after claying is this
    https://youtu.be/9b8erWuBA44
    Hahaha
    #2028
    Hahaha
    Hehehehe ngayon pa nga lang wala pa clay panay himas ko sa kotse paano pa kaya :D
    Mga kapitbahay ko na wi-wierdohan na yata sa akin, kahit gabing-gabi na basta umatake pagka OC nako labas agad lahat ng gamit at maglilinis ng kotse hehehehe.
    BTW anong polish ang madaling on and off?
    Mar 2015
    #2029
    Just did my first claying session the past few days sir, nakakapagod din pero sulit ang result. Like you, i was worried at first because i might do more harm than good. So i tried first a small panel (1/2' x 1/2') sprayed qd and clayed the surface. Medyo "maganit" yung pakiramdam habang rubbing ng clay nung una dahil sa contaminants, then sprayed qd again and rub until smooth na yung pasada ng clay sa surface while drying frequently with a waffle weave MF towel. Knead the clay once in a while if there are enough stains absorbed in the clay or knead when proceeding to the next panel. After an hour,finished almost half the car (surprisingly).
    The technique was liberal spray of qd on the surface to be clayed.
    More lubrication = safer claying.
    Claying one panel at a time.
    And as sir Stock Engine said: huwag mo ihuhulog haha
    #2030
    Nakakalakas ng loob yan DarkMatter Thanks!
    Mukhang mapapabili na nga ako hahahaha
    #2031
    There are new gen clay ( Nanoskin ) na. No worries of dropping. Just rinse with water and ur good to go. Faster to use than traditional clay.
    Similar to cg clayblock v2?
    #2033
    Quote Originally Posted by Ginnova View Post
    Where can we buy it?
    #2034
    Just an update on using Formula 1 Premium Paste Wax. I used it on the quarter panel glass and I could buff it clear with no problems. I'm gonna wait and see how much dust it will attract before I use it to seal the windshield.
    Aug 2004
    #2035
    saan meron nito available, sir locally?
    Mar 2015
    #2036
    Quote Originally Posted by mcbry View Post
    PM sir ginnova sir. Mukhang meron na sya :D
    Jul 2015
    #2037
    Quote Originally Posted by DarkMatter View Post
    Yes sir, I think meron si Ginnova.
    I got mine from Autogeek, kahit mahulog ay good parin. This is good for light claying. But if you need to remove more stubborn paint contaminants, a traditional clay bar will serve you better.
    Mar 2015
    #2038
    Nice sir, ano bang material nya if i may ask? Suitable din ba for clear plastics and headlight covers?
    Jul 2015
    #2039
    Yes pwede naman, parang sticky rubber yung material, then you have a foam handle. There is a version of this in towel form, baka mas aggressive din siguro yun, mas mahal nga lang din
    Local supplier ba ang autogeek? Or foreign? Ty
Detailing Thread [For Newbies][continued 3]
