Quote Originally Posted by RM Hobbyist View Post
Thanks Kitoy22. I think mas may fear ako na baka maging mali ang application ko ng clay bar kaya hindi ko pa siya binibili. Dami ko na pinanood sa youtube pero parang gusto ko pa rin makitang gawin muna ng iba at saka ko gagayahin hehehehe.
Just did my first claying session the past few days sir, nakakapagod din pero sulit ang result. Like you, i was worried at first because i might do more harm than good. So i tried first a small panel (1/2' x 1/2') sprayed qd and clayed the surface. Medyo "maganit" yung pakiramdam habang rubbing ng clay nung una dahil sa contaminants, then sprayed qd again and rub until smooth na yung pasada ng clay sa surface while drying frequently with a waffle weave MF towel. Knead the clay once in a while if there are enough stains absorbed in the clay or knead when proceeding to the next panel. After an hour,finished almost half the car (surprisingly).
The technique was liberal spray of qd on the surface to be clayed.
More lubrication = safer claying.
Claying one panel at a time.
And as sir Stock Engine said: huwag mo ihuhulog haha
