Page 114 of 127 FirstFirst ... 1464104110111112113114115116117118124 ... LastLast
Results 2,261 to 2,280 of 2535
    #2261
    Sa mga nakakaalam po jan. Ano po ba ang buffing? Pareho lang po ba ng polishing at ang buffing?
    Starmobile Up+
    Jul 2015
    #2262
    Quote Originally Posted by rodetor View Post
    Starmobile Up+
    Buffing is a general term used in the Philippines pag gagamitan ng makina yung paint, pang apply ng wax ng polish etc.
    To be more specific, yung polishing term na gamit ng detailer pertains to gloss enhancement and removing of paint imperfections/ paint defects, like swirls, mild scratches, paint oxidation etc with the use a synergistic combination of machine, pad and polishing cream (not wax).
    #2263
    Quote Originally Posted by Kitoy22 View Post
    Few days ago I have a part of a car body panel repainted. Kailangan pa raw i-buffing. Need ko pa raw ibalik, after the painted panel dried good, kasi nag-uulan. Yung painted panel, hindi smooth to see and touch. Naisip ko po, kung pwede magawa ko sa pagpunas ng wax na nabibili sa mga Ace Hardware.
    Starmobile Up+
    #2264
    Starmobile Up+
    the buffing comes as part of the re-painting, po. let them do it, sir. you are paying for it. they use rubbing compound, not wax. and it's physically much more difficult than just waxing. puede kung puede na kayo ang gagawa, but...
    lala-ke ang braso mo, kung kayo ang gagawa. and you'll probably get to feel like the hulk (he's always angry), somewhere along the way. 'tis better left to power tools and knowledgeable people.
    good luck, po.
    Jul 2015
    #2265
    Starmobile Up+
    dr. d is right, unless you want to be the hulk, pwede mo subukan. Yung wax po sir will protect your paint and will not do anything to make the paint smooth. Usually nag sasanding pa sila before they polish the paint. Pag direct polish/ buffing it will take more time and effort to get their desire results.
    #2266
    Thanks sa inputs nyo po dr. d and Kitoy22.
    Starmobile Up+
    Aug 2012
    #2267
    Starmobile Up+
    Buffing refers to the whole process. Polishing is part of buffing.
    The three stages of buffing: 1. Heavy cut to remove scratches. 2. Final cut and initial polish. 3. Final polish.
    Each stage uses different products. Cutting uses heavy and medium rubbing compound. Polishing uses cleaner polish and finishing polish.
    After buffing is complete, the paint should be shiny/reflective even without wax.
    Wax or sealant is applied afterwards for protection.
    Sent from my D5833 using Tapatalk
    May 2011
    #2268
    Tanong ko na rin po. Bakit kapag repainted na auto like wash over, etc. kelangan ibalik sa paint shop for buffing? Babawasan agad clearcoat para maging smooth? I mean bakit di kagaya ng factory paint na hindi dumaan sa buffing before irelease sa factory. Pero smooth and shiny agad paint from factory kahit may orange peel effect. Different process? Environment? Thanks po sa sasagot.
    Jul 2015
    #2269
    Quote Originally Posted by sparco21 View Post
    I think sir nag popolish parin kahit sa factory paint, pero minimal lang. Im not really sure, pero baka dahil machine ang nag aapply ng paint sa factory. Also often, pag sa body shop nag paint, mas makapal ang clear coat, kaya my allowance sila mag sanding at polish.
    Aug 2012
    #2270
    Factory uses clean room and robots. Paint formula, spray pressure, and speed are also controlled. Factory workers do buffing afterwards pero light or finishing na lang.
    Watch the paint process of factory here:
    Paint Shop | BMW US Factory
    May 2011
    #2271
    Quote Originally Posted by red_one View Post
    Kaya pala kalimitan pag repainted na sa body shop wala ng orange peel.Thanks po.
    Sep 2016
    #2272
    Meron po bang nagpapaint dito at also mechanic? All in 1 ba kung baga. Ay project kasi ako eh. Baka meron expert dito.
    Sep 2016
    #2273
    Hi Sir/Mam, any member/s here na nakatira sa Manila area (Ermita, Malate, San Andres, Paco, etc.)? First time car owner kase ako, di ko alam kung merong reputable/trusted auto detailing shop/s sa area natin. May mga nakikita ako along the streets pero di ko sure kung subok na sila. Baka may mga suggestions kayo. Suggestions from vicinity of Manila are all welcome too. TIA
    Nov 2014
    #2274
    Quote Originally Posted by Optimus-Prime View Post
    Prautotype along Zobel Roxas. Havent tried it yet because when I pass by that area it's still closed, but friends recommend it.
    Sep 2016
    #2275
    Quote Originally Posted by kai s. View Post
    Thanks sir!
    Oct 2015
    #2276
    Hi
    Newbie question.
    Balak ko kse mag DIY waxing, para matanggal mga watermarks.
    Advisable ba na mag clay muna or sa Wax lang matatanggal na yung mga watermarks?
    Gumamit na ko ng Microtex NanoSliq after carwash pero andun parin yung mga watermarks.
    Apr 2012
    #2277
    check mo Ziebart Manila sa may Paco, Big Berts sa Araneta Ave.
    Sep 2009
    #2278
    Quote Originally Posted by coymac03 View Post
    Hi
    Newbie question.
    Gano katagal na ba watermarks? Baka di n kayanin ng clay at wax. Polish n kailangan. Try a test spot.
    Sent from my STUDIO ENERGY 2 using Tapatalk
    Oct 2015
    #2279
    Quote Originally Posted by jkatzify View Post
    Mga 2 weeks na siguro, pangalawang carwash ko na nde parin natanggal.
    Bumili ako step 1 to 3 ng Microtex sachet, itry ko.
    Sana matanggal.
    Jan 2011
    #2280
    Help po Paano ba mag polish ng car? plan ko mag polish muna then wax after. anong brand recommended nyo at steps?san din makakabili? malapit pala ako sa Mothers Detailing Shop sa Santolan across Concept One. faded na kasi oto ko kaya mas ok yatang i-polish narin sya. Pa-advise muna sana ako. thanks!
Detailing Thread [For Newbies][continued 3]
