Results 2,021 to 2,030 of 2535
- Sep 2015
- 11
September 3rd, 2015 05:47 PM #2021Guys starting pa lang ako sa detailing. Sobrang daming back read hehehehe.
I have a silver 2014 vios. By hand lang ako at eto ang mga gamit ko for now. Microtex Car Shampoo, Formula 1 Premium Paste Wax, NanoSliq and Glass Science Glass Scrub.
Next project would be to have the car clay barred. I'm debating buying my own or just have the detailer do it. From my list any pros and cons and ano pwede ko idagdag para sa complete protection?
Follow up question. Pwede ko ba gamitin yung formula 1 premium paste wax as sealer sa windshield kahit sabi sa details niya na hindi daw pwede? Pwede kasi siya sa headlights eh so i figured baka pwede din sa windshield?
Pasensya na sa mga noobie na tanongSalamat
September 3rd, 2015 05:55 PM #2022
If the cost of the clay bar kit is acceptable sayo sir, I think mas ok na bumili ka, since long term investment nman to.
September 3rd, 2015 05:58 PM #2023
Ayus yan glass science scrub. Use a wet sponge to utilize it properly. Use it lng if water spots cant be removed with regular wash. Otherwise dont use it. Im using bottled water as washer fluid now so ive stopped using glass science scrub.
You can try sa second row glass yan wax. If you can buff it to clear clarity then wax away your windshield. Buffing windshields will cause glass to collect dust much faster. After buffing use cold distilled water with mf to neutralize the static. Just wet and dry. Avoid buffing. Thats my rain prep.
- Sep 2015
- 11
September 3rd, 2015 06:04 PM #2024
- Sep 2015
- 11
September 3rd, 2015 06:22 PM #2027
Your new theme song after claying is this
https://youtu.be/9b8erWuBA44
Hahaha
- Sep 2015
- 11
September 3rd, 2015 06:36 PM #2028Hehehehe ngayon pa nga lang wala pa clay panay himas ko sa kotse paano pa kaya :D
Mga kapitbahay ko na wi-wierdohan na yata sa akin, kahit gabing-gabi na basta umatake pagka OC nako labas agad lahat ng gamit at maglilinis ng kotse hehehehe.
BTW anong polish ang madaling on and off?
September 3rd, 2015 07:09 PM #2029
Just did my first claying session the past few days sir, nakakapagod din pero sulit ang result. Like you, i was worried at first because i might do more harm than good. So i tried first a small panel (1/2' x 1/2') sprayed qd and clayed the surface. Medyo "maganit" yung pakiramdam habang rubbing ng clay nung una dahil sa contaminants, then sprayed qd again and rub until smooth na yung pasada ng clay sa surface while drying frequently with a waffle weave MF towel. Knead the clay once in a while if there are enough stains absorbed in the clay or knead when proceeding to the next panel. After an hour,finished almost half the car (surprisingly).
The technique was liberal spray of qd on the surface to be clayed.
More lubrication = safer claying.
Claying one panel at a time.
And as sir Stock Engine said: huwag mo ihuhulog haha
- Sep 2015
- 11
September 3rd, 2015 07:21 PM #2030Nakakalakas ng loob yan DarkMatter
Thanks!
Mukhang mapapabili na nga ako hahahaha
Are mandatory seatbelts, and minimum brightness standards for exterior lighting also woke elements?
Carbon fiber hood
