Results 1,921 to 1,930 of 2535
- Jul 2008
- 479
June 25th, 2015 03:29 PM #1921anyone knows kung saan pwede maka bili ng porter cable backing plate? thanks
- Jun 2004
- 496
- Aug 2010
- 117
June 25th, 2015 10:06 PM #1923keep your regimen simple. wash/dry > clay > polish > apply sealant or wax. you can skip the claying and polishing if smooth pa at makintab yung paint surface then do the normal wash and wax.
read the Tamang OC thread from the beginning and you will learn a lot...
When you sa "apply sealant or wax" sir, i will only apply only one of these two? or pwedeng lets say, Megs NXT tech wax or Mother & Megs step 2 then top up ko ng Collinite as my LSP.
ang gulo talaga sir, nakakalito hehehe. actually nalilito ako about sa sealant, polish and glaze. ang nakakalito eh yung next step after claying at before applying ng wax
- Sep 2011
- 241
June 25th, 2015 11:47 PM #1924The way I see it, you have 2 parts in detailing the exterior of a car: Preparation and Protection.
Once you prep the surface parang hubad yan wala sya protection. Claying, compounding, polishing is under the prep part. I usually assume that Claying and compounding is more aggressive than polishing so inuuna ko muna si clay then si compound and last ko si polish. ( Compound and polish in what I do is optional, usually once or twice a year ko lng ginagawa depende sa condition nung paint ).
Protection usually involves the sealant and waxing part. I assume that the sealant I use is more durable than the wax, so inuuna ko muna si sealant then I layer the wax above it. ( plus I like the finish of my wax than my sealant ). Pag di ka nag prep at dumiretso ka sa protection, pwede rin naman pero the result might not be as great kung may prep part and the durability of your protection might not be as good.
Then there are products that fall in both categories, pasok ata dito si Klasse AIO, kaya nga siguro siya all in one?. I usually apply KAIO as my last step in the prep part. Then the Glazes, pwede siya pang prep since it can hide minor imperfections pero sakin kung ok compunding/polishing mo you might not need it, I don't know if it can protect but some glazes will tell you it can add gloss and depth to your paint ang di lang ako kampante is that it may degrade the durability of my sealant and wax since nakapatong sila sa glaze, so in my regimen I dont use glazes ;)
In between my detailing regimen is my maintenance part, this usually involves washing your car and applying your quick detailer. BTW I wash the car prior to claying ;)
June 26th, 2015 01:53 AM #1925
polishing is prepping your paint surface para maalis lahat ng defects bago ka mag-apply ng LSP. cleaner wax or prewax cleaner as the name implied ay gaya ng nasabi mo inaapply bago magwax to get rid of mga residues during polishing para maganda kapit ng sealant o wax. i have no idea sa mothers at megs eh.
you can apply sealant or wax alone as your LSP or pwede magkapatong. rule of thumb is sealant muna then let it cure or give time to bond sa paint bago mo patungan ng wax.
para di ka malito, just follow yung basic regimen na wash > clay > polish > LSP. yung glaze is parang filler lang to hide imperfections kung hindi natanggal lahat during polishing. halimbawa merong scratch at swirls na hindi natanggal during polishing pwede maitago yan ng glaze para looking makinis yung paint surface.
after claying is polishing, either by hand or machine. dito mo inaalis mga imperfections ng paint like swirls, gasgas, mga oversprays etc. kapag severe yung condition ng paint need mo mag compounding, if mga swirls lang at minor scratches pwede na yung mga swirl removers. try to read mga detailing sites like autogeek, detailed image at autopia, maraming mga write ups about detailing, tamang paggamit at application ng mga polish/sealant/waxes. read back karin dito sa mga forum ng tsikot sigurado mga tanong mo may sagot na somewhere. enjoy detailing
- Aug 2012
- 2,767
June 26th, 2015 09:44 AM #1928*ronmayajoan: Sa simula lang nakakalito dahil hindi ka pa familiar sa mga products ska if iba-ibang brands ang gusto mo gamitin. Just follow these steps and you will now get lost. Alamin mo kung para saang step ang product na binili mo.
- Jun 2004
- 496
June 26th, 2015 04:13 PM #1929
- Mar 2010
- 2,273
June 26th, 2015 04:37 PM #1930If it's a brand new ertiga car which way to go, BB Optiguard, or I try to do the maintenance and which procedure and what is the locally available materials?
TIA
TIA
Jay Leno Drives the 2024 Toyota GR Corolla — Rally Rocket for the Streets! | Jay Leno's Garage Jay...
2023 Toyota GR Corolla Hatchback
