Quote Originally Posted by ronmayajoan View Post
thank you for the reply sir. with regards to polishing medyo hindi ko po maintindihan ito eh, eto din po ba yung cleaner wax or prewax cleaner? tama po ba ko sa pagkaka intindi na ina-apply ito to prepare the paint for waxing? at inaalis nito yung old wax buildup para sa new layer ng wax? in that case po, pwede ko po ba gamitin Mothers Step 1 or Megs Step 1 for this?
When you sa "apply sealant or wax" sir, i will only apply only one of these two? or pwedeng lets say, Megs NXT tech wax or Mother & Megs step 2 then top up ko ng Collinite as my LSP.
ang gulo talaga sir, nakakalito hehehe. actually nalilito ako about sa sealant, polish and glaze. ang nakakalito eh yung next step after claying at before applying ng wax
The way I see it, you have 2 parts in detailing the exterior of a car: Preparation and Protection.
Once you prep the surface parang hubad yan wala sya protection. Claying, compounding, polishing is under the prep part. I usually assume that Claying and compounding is more aggressive than polishing so inuuna ko muna si clay then si compound and last ko si polish. ( Compound and polish in what I do is optional, usually once or twice a year ko lng ginagawa depende sa condition nung paint ).
Protection usually involves the sealant and waxing part. I assume that the sealant I use is more durable than the wax, so inuuna ko muna si sealant then I layer the wax above it. ( plus I like the finish of my wax than my sealant ). Pag di ka nag prep at dumiretso ka sa protection, pwede rin naman pero the result might not be as great kung may prep part and the durability of your protection might not be as good.
Then there are products that fall in both categories, pasok ata dito si Klasse AIO, kaya nga siguro siya all in one?. I usually apply KAIO as my last step in the prep part. Then the Glazes, pwede siya pang prep since it can hide minor imperfections pero sakin kung ok compunding/polishing mo you might not need it, I don't know if it can protect but some glazes will tell you it can add gloss and depth to your paint ang di lang ako kampante is that it may degrade the durability of my sealant and wax since nakapatong sila sa glaze, so in my regimen I dont use glazes ;)
In between my detailing regimen is my maintenance part, this usually involves washing your car and applying your quick detailer. BTW I wash the car prior to claying ;)
