Page 30 of 127 FirstFirst ... 202627282930313233344080 ... LastLast
Results 581 to 600 of 2535
    Apr 2010
    #581
    ako sponge lang na napulot ko sa fort taguig after a fun run.. daming sponges na naka kalat sa kalsada! ahihihihi!
    Oct 2011
    #582
    915 shine..
    Ang dami parin ng 915 ko. Sobra sulit yung pagka-bili ko (50% off sale)
    Iba talaga ang dating ng Sportage. Miles apart compared sa Tucson imho.
    #583
    Quote Originally Posted by GTS925 View Post
    Royal Place?
    Ang ganda talaga ng Sportage!
    Masyado bang halata kung saan?
    Thanks.
    Iba talaga yung dating especially sa front. Sides and rear parang Tucson parin. Hehe
    Oct 2011
    #584
    Thanks.
    yes, ganda ng front. kailangan ma facelift agad itong Tucson para ma consider ko.
    Jun 2011
    #585
    papansin lang po baka po malapit kayu dto sa lugar namin car wash and autoworks po kami,dinaman cgro masama mag post ako dto kc bandang cainta po kami,baka po may maitulong ako dto.
    Oct 2011
    #586
    Quote Originally Posted by mikehunter1980 View Post
    malapit ba kayo sa junction?
    Jun 2011
    #587
    malapit kami junction
    Oct 2011
    #588
    Which car color is the hardest to maintain and conversely, which is the easiest to maintain and why?
    Jul 2011
    #589
    sir sa experience ko silver pinakamadali i-maintain. di masyado halata mga water marks at alikabok, kahit ung mga micro scratches/swirls kailangan mo talaga titigan bago mo makita.
    Aug 2008
    #590
    Hardest is non-metallic black - every single scratch and blemish can easily be seen, as well as any dust or dirt on the car. Easiest, as mentioned, is light metallic silver, where it's really difficult to see swirls or scratches, and dust blends in with the color of the car.
    Oct 2011
    #591
    Quote Originally Posted by umi001 View Post
    okay, thanks sir umi.
    Oct 2011
    #592
    Generally, are all wax and polish products applicable to all car paint color? The reason I ask this is that I saw some products like Mothers and Meguairs that have waxes that are exclusive for black color paint car (correct me if im wrong as i have only seen the label).
    Oct 2011
    #593
    Follow-up question on carnauba wax:
    How often do you apply carnauba wax in your car? and does carnauba wax "thins" your car paint? may negative or side effects ba in applying this type of wax? TIA.
    #594
    Sir, am no expert, but have been reading (and buying) a lot on detailing products. The carnauba waxes do not thin the paint. The products that thin the paint are those with abrasives, like compounds and polishes. So no side effects in applying carnauba waxes. There a also "Carnauba cleaner waxes" and these supposedly clean and wax the paint at the same time, you can check the label if it has abrasives.
    A very good guide is the posted thread at the top of this section: "Tamang OC lang...", this is what started me in giving the proper care to our cars. And then I also joined pinoydetailing.com...and then after a few thousand pesos, our car is a little shinier, with a little less scratches and swirl marks. And I've been enjoying myself learning how to do it. I know you will too...
    Oct 2011
    #595
    Quote Originally Posted by loverlionus View Post
    okay, salamat bro.
    Oct 2011
    #596
    Yes, it's called beading - all waxes and sealants exhibit it, to a greater or lesser extent. A few larger shots (this is with Dodo Juice Supernatural Hybrid as my wax):
    Sir Umi, I hope I get same result when I apply Microtex NanoGlos to my car.
    Oct 2011
    #597
    Is 'waterless car wash' synonymous to spray wax or quick detailer?
    Aug 2008
    #598
    I'll be honest, I've not had much experience with Nanoglos. I have used it two or three times, but the last time was back during the summer, and I never saw it rained on. That said, you will get beading with it, but I don't know if it'll be as good as what I showed you - that was with Dodo Juice Supernatural Hybrid wax on the car, and it's got the best beading properties I've seen among the products I've used to date (the Collinite waxes come close, but I felt that the SNH beading was just that bit better).
    A little different.
    QD: For light cleaning (minor dust, finger prints and smudges); usually also adds gloss and slickness, but very little (if any) protection
    spray wax: Should only be used on a clean surface; adds some protection, and hence also some gloss and slickness
    waterless wash: For light to medium cleaning (heavier dust, light water/rain marks); may add some gloss and slickness, usually doesn't add any protection (though Meguiar's new Ultimate Wash and Wax Anywhere will be an exception).
    Oct 2011
    #599
    thanks for the reply sir Umi. Noted mga comments mo.
    Mar 2011
    #600
    ganda ng beading bos umi..ganito beading sa sasakyan ko pag nababasa o naulan..ibig sabihin effective ginagawa ko..hehehe
Detailing Thread [For Newbies][continued 3]
