Results 231 to 240 of 2535
March 8th, 2011 10:19 AM #231
you should at least clay before waxing. you're doing less harm than just leaving the paint without wax. marring/swirls, maybe, but you minimized water etching which runs deeper into the clearcoat.
March 8th, 2011 10:08 PM #232
Just bought Optimum Poli-Seal & Car Wax and will try my first detailing this weekend
on my 3 month old car and as suggested on this forum, Poli-Seal muna then top-off with Car Wax. Kailangan ko pa ba mag-clay bar before the waxing at OK din kaya ang results pag hand application lang lahat? Thanks in advance.
March 8th, 2011 10:44 PM #233
Ayos yang combo sir ganyan gamit ko ngayon maganda results sa Jazz ko. Mas maganda kung i clay muna ang surface para matanggal lahat ng contaminants. Yung poliseal pwede yan hand application dapat lang siyang i work para magamit yung cleaning properties niya.
March 9th, 2011 01:44 AM #234
whew ang haba ng threads for this... kapagod mag back-read pero ang daming kong natutunan...
- Jul 2010
- 6
March 9th, 2011 08:43 AM #235Sinubukan ko kanina yung Poli-Seal sa small portion sa hood ko gamit ang MF towel at separate MF towel for buffing; after application ay madulas yung surface at medyo shiny. Question lang po, kailangan bang may slight pressure pag nag-apply nito at parang di ko nakita yung slight hazing sa surface before I buffed? Baka kailangan ko pa itong iwan ng ilang minutes bago i-buff. Thanks in advance for all your inputs.
March 9th, 2011 04:19 PM #236
March 9th, 2011 04:44 PM #238
Dapat slightly moistened Foam pad applicator dapat ang pang apply with moderate pressure at dapat maka ilang passes ka sa bawat panel para ma clean ng poliseal yung paint. Personally iniikot ko muna yung buong car then wait ako mga 30 mins then buff ko yung unang part na na applyan ko.
March 9th, 2011 05:34 PM #239
Natapos na ako mag-wax ng Poli-Seal then top-off with OCW using hand application. So far satisfied naman ako sa 1st try ko ng detailing dahil shiny at naalis yung mga light scratches ng mga bata sa lugar namin:
I hope the PH government will one day remove all the traffic management responsibilities in the NCR...
SC (temporarily) stops NCAP
