Results 731 to 740 of 1575
November 17th, 2010 01:49 AM #731
Guys, I won't be able to join you this sunday (POLISHING)...... for NEWBIES I STRONGLY SUGGEST you join the one in katipunan....
*ChiX.... thanks for the MAP
- Feb 2010
- 234
November 17th, 2010 04:57 AM #732I'm about to get my 476 and Klasse AIO c/o my Auntie.
Here's my plan once I receive them and a claybar set (Mother's)
1. Carwash
2. Claybar
3. Klasse AIO (to polish the paint)
4. 476 as the LSP
My ride is a 2010 Adventure (Black) that was acquired March 2010, so far there are only minor/minimal swirls on the paint, mostly on the roof and hood.
I was planning to do some polishing as well, maybe use either Swirl-X or Mother's Step 1/2..but I think that Klasse would be enough.
What do you guys/gals think? Any suggestions?Last edited by Big_daddy; November 17th, 2010 at 04:59 AM. Reason: update info
November 17th, 2010 05:31 AM #733
- Feb 2010
- 234
November 17th, 2010 06:12 AM #734Yep, you're right, I forgot the wash after the clay bar...and unfortunately, I only have the Klasse AIO, what I do have is FX Synwax...will that work as a sealant?
1. Carwash
2. Claybar
3. Carwash
4. Klasse AIO (to polish the paint)
5. FX Synwax
6. 476 as the LSP
How about this?
November 17th, 2010 07:22 AM #735
better if you use KSG after KAIO. No need to put FX. 476 will be more than enough
- Feb 2009
- 171
November 17th, 2010 09:41 AM #736Question, Is it ok to use Megs Ultimate compound in replacement on Mothers step 1? i've noticed that Moms step 1 is more abrasive than megs UC. Together with that Megs UC gives the shine and cure for some defects. Followed by any wax as step 3. I think it is ok not to use step 2 since the shine coming from the Megs UC is enogh and using step 2 will no loger do dramatic effect on the paint. Like Megs UC the NXT 2.0 every week?
Any advice?
November 17th, 2010 10:22 AM #737
Megs UC is definitely more abrasive than mother's step 1. Using it weekly will badly affect your clearcoat, as our gurus say.
November 17th, 2010 11:03 AM #738
November 17th, 2010 11:53 AM #739
Guys, what kind of product do u suggest I use in removing grime and dirts in wheel wheels? May available ba na spray on product na effective in removing it? Kung normal shampoo lang kasi, parang medyo mahirap tanggalin.
November 17th, 2010 01:07 PM #740
would just like to thank sirs frenchtower, watusi, hammerdin, and indiej for the suggestions. used cleaner wax palang naman, pero nawala talga yung libag! matutuwa si erpats nito. thanks ulit mga sir!
:clap:Last edited by jeDi13; November 17th, 2010 at 02:01 PM.
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
