Results 2,421 to 2,430 of 5910
- Mar 2007
- 65
March 5th, 2007 06:15 PM #2421so bossing oks lang to clay then wax the new car? any brand you can recommend?
wala bang promo or paint program sila bossing theveed for new cars?
thanks...
Tsikot Member Rank 3
- Mar 2004
- 2,053
March 5th, 2007 06:46 PM #2422Yeah... it should be okay.
The only detailing clays I've seen available are Mothers (sa True Value) and Soft99 (sa Concorde). Old stock na yung Soft99 sa concorde old stock na. I forgot how much they cost though.. siguro nasa 1kphp range.
Meron yan. Try visiting their website or sending him a PM.
Actually... it would probably be more practical if you send your car to his shop for the initial treatment. Tapos, just maintain by regular washing and waxing.
Tsikot Member Rank 4
- Jun 2006
- 2,605
March 7th, 2007 10:39 AM #2423Question lang on EO WAUD, I mixed it 1:1 with distilled water for use as a QD, bird dropping cleaner. Can I use it under direct sunlight?
March 7th, 2007 11:41 AM #2424
its been a while since I visited this thread.. mahaba-haba na pala. I've been purposely avoiding to polish my ride for a couple of months na. gusto kong ipunin yung swirls and light scratches muna before removing them. finally decided to start at it this weekend. hehehehe
userfriendly: QD under direct sunlight? I think I've done that before during times na OC talaga ako but normally, I try to avoid that.. kung tulad na ng bird poo, pinapaabot ko na lang sa bahay tapos diretsong car wash. usually, I QD when the vehicle's alot cooler.
bankai: there are different kinds and qualities of MF's available out there. try to look for the ones that are really plush and offer good nap.. BTW, anlaki ng towel na yan ah.anyway, how is it so far?
antz-z: yup, go ahead and detail your car. maganda nga habang brand new pa lang you're treating it right. helps a lot to preserve the looks of your car. last time I checked, yung Soft99 clay nasa 600 petot lang. pero that's old stock na so you're better off with Mom's.
- Mar 2007
- 65
March 7th, 2007 02:32 PM #2425thanks sa advise bossing... f/up question ko lang, what's the step to preserve yung paint ng new car? tama po ba 'tong natutunan ko or meron pa po bang kulang?
1. wash using 3m car shampoo
2. dry using microtex yellow cloth
3. dilute 3m car shampoo with water then apply sa car bago i-clay using soft99 <- is this step necessary?
4. rinse with water then dry
5. wax with mother's carnauba (since red yung color ng car)
6. apply eagle 1 wet wipe & shine
thanks...
March 7th, 2007 04:05 PM #2426
never hurts to clay.
hindi naman nakakapagod mag-clay. just glide.
helps a lot in smoothening out the surface of your ride. just make sure to lubricate the surface.
yung QD can be used together with CCD in between car-wash sessions as maintenance in between your major details unless your car's really dirty (dried up mud, rain / nabasa...). in this case, washing your car is your best bet.
- Mar 2007
- 65
March 7th, 2007 04:28 PM #2427so bossing, ok na yung mga steps na ni-list ko? no need for the glaze, polish, seal steps? medyo naguguluhan pa kasi ako dito sa 3 steps na 'to e..
salamat...
March 7th, 2007 04:39 PM #2428
in truth, mahirap i-base ang detail plan on a defined "generic" 3-step method. rather, its more of what your car actually needs and what you can actually do about it.
at this point, since brand new pa ang car, you can apply some glaze and seal your car with either a sealant or wax. as for polish? I'm willing to venture na wag muna...
after some time, you can "clean" and polish your car to bring back its luster and shine then seal with your preferred LSP.
- Mar 2007
- 65
March 7th, 2007 05:28 PM #2429in between what steps po below ko ilalagay yung pag-glaze and pag seal? also, any brand you can recommend for glaze? seal?
salamat...
March 7th, 2007 08:27 PM #2430
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
