Results 171 to 180 of 5910
May 17th, 2005 11:44 AM #171
Blackmagic: Where can I buy the Moms Claybar (only) without the cleaner wax and QD?
May 17th, 2005 11:48 AM #172
Blackmagic: Great tip sir! Thanks! Excited na ako subukan sa car ko! Ako pala yung tumawag and nagdeposit kanina! Thanks uli!
May 17th, 2005 11:57 AM #173
ganda talaga ng Mom's claybar! matigas kasi yung sa Soft99 hehehe. nga pala, don't ever drop the claybar. ang bilis maka-pick-up ng dirt.. BTW, soapy water (car shampoo + water) can act as a lubricant.. some dilute their QD's for this purpose too. (1:1)
ILD: I think you can work something out sa Autoplus regarding that..
May 17th, 2005 01:26 PM #176
yup.. it safely removes contaminants. tapos you knead the bar again to get a fresh piece. you can re-use it again this way again and again. make sure to use a lubricant when using clay.
you should clay after washing your car.
May 17th, 2005 03:43 PM #177
Hmm.. So the process would be like
1) Wash and dry
2) Clay
3) Polish
4) Wax
right? BTW If use soap and water as lubricant for the clay, I guess that would mean I would need to rinse the soapy water off right? Or can I just wipe it off (since I think that's the way to do it with clay + QD)?
May 17th, 2005 03:48 PM #178
Originally Posted by patopig
May 17th, 2005 04:48 PM #180
so ang steps dapat is,
1. wash and dry
2. clay and repeat step no. 1
3. polish
4. wax
where do the cleaner wax comes in? right before no. 3?
^Thanks for the advise guys. Already replaced all.
Rubber boot question (repair or replace)
