*dadmonpogi: its ok to use that after using QD, but to get the best results, it would bond more properly to the paint if you apply it directly after washing your car, its usually Spray wax and then QD. If you are using a QD to lightly clean the car, the bonding of the spray wax would depend on the type of QD you used, if you are using a very slick QD it might affect the bonding of the wax, but if your QD leaves a very clean surface without being too slick then you spray wax would have a better chance to bond to the paint. Honestly right now im using Mother Fx Spray wax and im already using it as a QD and spray wax in one, in not endorsing mothers, but there are also some spray waxes out there that also acts as a QD.
Its ok compared to standard dusters we see, but there are better like Microtex Duster and California Car Duster. You could find the Microtex Duster at any Hardware stores. As for the California car duster, its available at some blade outlets, True Value and SnR membership shopping, or you could get it directly from the mothers distributor 7445875. I tried the duster from concorde and its ok in the sense that the fingers are soft but it doesn't play too well when it gets dirty, unlike the two car dusters i mentioned above. Its also a little tougher compared to the two i mentioned to there is more pressure against the paint, but what i like about this is that its re-washable, unlike the previous two i mentioned. Its a good deal but you have to slightly glide it across the paint to avoid putting pressure and it doesn't cover that well but all in all its a good deal especially since you can re-wash it.
Hope this helps
.. Every week washing is of course a must dahil madungis ang white pag marumi.. Also watch out for asphalt sticking onto the paint dahil sobrang visible siya sa white
![Google Play Detailing Thread [For Newbies][ARCHIVED]](https://play.google.com/intl/en_us/badges/images/generic/en_badge_web_generic.png)
