Originally Posted by
madkatz
*jeff: generally polishes like these, when hand applied, are applied using a Foam applicator pad. You could check or buy any foam applicator pad available in the market, if you could still find some Zwipes MF + 2 Applicator pads, thats a nice deal since its just 170 and you get a large MF and 2 applicator pads already, Megs cost 88 pesos i think, and SM arnolds cost like 70 to 80? but generally any foam applicator pad should be ok.
As for applying the product basically its the same as my advice to chickselog,
1. apply it on one small area at a time to ensure even pressure
2. use light to moderate pressure and always check from time to time if it has removed the defect.
3. as for this product i would recommend working the product from both horizontally and vertically, i wouldn't recommend overlapping circular motion with this product
4. try to follow it up with a milder polish if the finish is not as glossy
5. never buff dry
6. don't use too much product since using too much will also remove more paint and we don't want that to happen
7. always buff it out after working the small area to prevent polish build ups
8. always check for uniformity of results and always check the panel you've done
9. do it with proper lighting
10. this takes a longer time to work the polish so thats about 5 minutes per 2x2 ft area with light to moderate pressure depending on the defect you are correcting
11. always test on a small not so noticeable area to check if you are ok with the products result before doing an entire panel or before doing the entire car. there are some instances that some people are not happy with the finish and gloss of their polishes
You could dampen the applicator, but not too wet, just damp, to help it spread the wax easier and have less wax absorbed inside.
but i prefer using QD, if not i prefer going straight to the wax.
No problem, feel free to ask, Hope this helps
