Originally Posted by
madkatz
*indiej: its better to wash the foam pads after you use it, just like what chickselog said, hardened wax might induce swirls on your paint, and another thing to note is that hardened wax is a lot harder to remove.
*jeff: yes you can use it for the whole car, but before you cover the whole car, do a test spot first and check if you are satisfied with the results, TW scratch and swirl remover is actually a bit aggressive IMO, its texture is pretty much like some compounds already so in using this product be sure to use light pressure only, and as far as i know this product does a decent job in removing scratches and swirls but it does not finish to a high gloss finish so you have to follow it up with a cleaner wax or with an ultra finishing polish, you could use Moms or Megs Step 2 to enhance the shine of the paint after your application of TW Scratch and Swirl Remover.
*chickselog: im leaning towards the Megs Applicator pad i guess because of the slight added thickness in the foam property, i believe adequate foam thickness would help in reducing hard buff marks.
Alright Good luck on your prelims, be sure to study well and just take care of the detailing after your exams! My sister is also taking her prelims in UST this monday wednesday friday and saturday hehe
