At 1 ATM (1 bar) water's boiling point is 100C.
At 1.1 bar its at 102C, at 1.2 bar is 106C.
If your engine is overheating, that radiator cap really does little but pressurize your system making it more prone to leaks at the joints.
The reason why you want to defer boiling is because a phase change from liquid to gas makes water 40,000 time less conductive and it pressurizes the whole loop.
Then your cylinder heads glowing red hot and start warping.
If you really want to raise your boiling point without pressurizing, increase your coolant-water ratio. However, it doesn't mean just because you're not boling the water component from your coolant, that your engine isn't running hot.
Or go with a waterless coolant, 196C boiling point, and since there is no vaporization there is no pressure build up. You can practially do away with a pressure cap.
