Yeah... having internet issues.
I was going to say... check your water pump... metal shavings probably mean your water pump is on its way out.
The solution to your cap dilemma should be: replace the hoses. They're the most probably failure point in your system.
Yes sir I will be replacing hoses. You've kinda answered me indirectly that I can use 1.1 cap if I've established no weak points in the cooling system.
These metal shavings are like powdery na. pag na salok mo sa tubig at tried to rub it against fingers na-didissolve. Still these are metal shavings right? Or aluminum corrosion lang? Either way, since hindi ko alam history ng water pump. I'm going to change it.
