Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
    Aug 2012
    #21
    Quote Originally Posted by EVO-V View Post
    At 1.1 bars the boiling point of water is 102C. If by any chance your radiator finds itself having a hard time keeping you below 96C, the high pressure cap is the least of your concerns. Don't strain your system any further.
    And seriously, radiator "overhauling" is really a bandaid for light vehicles. There are a host of cheap radiators you can get nowadays. Get a new one. Don't skimp. An engine overhaul is just one overheating incident away from ruining your month.
    And yes, for the record I do understand na why I should not go 1.1 cap for now.
    Thanks for clarifying.
    Since marami pang weak points sa system like old radiator hose, overhauled radiator, etc.
    I understand 0.9 cap is optimal for now.
    Feb 2009
    #22
    Nope you won't. If by the time you even reach the boiling point using a waterless coolant, your engine would have long shut itself off.
    And since you really don't have air, assuming your cooling system is properly primed, there would be no cavitation issues for the pump to deal with.
    Attachment 23161
    have you tried and tested what you mentioned?
    yeah tell your science to all the automotive engineers. this might be a breakthrough, vitch
    Aug 2005
    #23
    Yes. Jay Leno uses the same solution for his collection as they do a great job for maintenance free corrosion inhibition.
    Don't need to. They already know it.
    But waterless coolants are expensive and it doesn't give them return business for preventive maintenance. So it depends on what you want to achieve.
    Feb 2009
    #24
    wow, i was amazed and counting on another filipino genius like yourself to have discovered a breakthrough just like what i thought you insinuated was a discovery. turns out to be a previously known product.
    Aug 2005
    #25
    Thank you, glad we can contribute to your wonderment. Fortunately enough, we can't account for every nitwit's malicious imagination. ;)
    Previously mentioned here:
    http://tsikot.com/forums/aircon-temp...ml#post2211758
    In case you're missing the point, the use of waterless coolants are more prevalent in extreme applications. The economics of efficiencies differ across segments. For large diesel engines its a matter of increasing efficiency and extending engine life. For cars its mostly for preservation.
    And if you were to ask the obvious again, yes we work with waterless coolants regularly. This is industry insight meant to aid people who are asking not people trying to know it all. So try not to get too touchy about this matter.
    Oct 2014
    #26
    Natanggal yung Rad Cap that resulted to my radiator to loss all its content and resulting to overheat. I put about 8liters of water muna as i still have to check responses either to bring my ride to a mechanic before replacing coolant. Initially replaced the cap and check this morning and still ok. My concern is if its ok to replaced my radiator with coolant and not anymore bother to bring it to a mechanic? TIA.
    #27
    Quote Originally Posted by Gian Paulo View Post
    if i were me, i'd have replaced the liquid with the proper coolant mix already. why replace it with plain water first, and then... wait for what?
    your mechanic will probably say the same thing.."observe the car".
Yet Another Radiator Cap Pressure
