Page 5 of 10 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 197
    Jan 2011
    #81
    Quote Originally Posted by EVO-V View Post
    7138 the solution I am providing is knowledge. No product endorsements whatsoever.
    lowslowbenz seems to have been irked when I said you don't really need to use distilled water. The simplest choice is that you don't use hard water and complement it with a coolant. That minimizes deposits. Done.
    uls is just upset with himself all the time.
    Sorry for this laymans question, paano malalaman kung yung tubig is hard or not.?
    Oct 2011
    #82
    Pa laboratory exam natin ang kalidad ng ating tubig sa Maynilad or Manila Water accredited testing agency. Kung safe ba ito sa radiator.
    Aug 2005
    #83
    SM distilled water lang nilalagay ko sa mga Benz. And I flush it every 6 months, I don't use coolant.
    Ni minsan, hindi ako nag-overheat, tirik ang araw tanghaling tapat sa Coastal, sa Aguinaldo, sa Baclaran, sa EDSA, sa Makati.
    Then good for you. Pure water is a good conductor of heat, glycol diminishes its thermal capacity.
    Thing is you flush your system every 6 months. How does the water look like then?
    It isn't how water per se affect your radiator's cooling capacity, but its reliability. Remember the problem you're incurring here is that water alone will boil very quickly. Your linings are going to be more vulnerable to cavitation and corrosion.
    Oct 2011
    #84
    Quote Originally Posted by 2rm View Post
    Through laboratory testing.
    Aug 2005
    #85
    Simplest test is to see how well it suds.
    Hard water doesn't produce as much suds. (Hindi bumubula)
    Mar 2012
    #86
    got the same question.. ice nasa utak ko.
    Aug 2005
    #87
    Quote Originally Posted by stickers View Post
    When you shower and the water in your location is hard, you'd notice that when you lather soap or shampoo, they don't foam as much and do not wash off as easily.
    You would also notice that your stainless appliances, say an electric kettle, will have stains.
    Aug 2005
    #88
    You can actually call them to test the water in your locality but I doubt they'd entertain you for those reasons.
    Jan 2011
    #89
    Is it safe to say na yung mga purified water na nabibili per gallon at distilled water ay hindi hard water?
    pag ang GTOil naglabas ng coolant......
    panis lahat ng nilalagay niyo sa radiator
    Aug 2005
    #91
    If the place where you bought from treats their source by softening and filtration then yes.
    why not?
    dito sa Pinas mas concerned tayo sa kalusugan ng radiator kesa sa kalusugan ng tao
    Dec 2009
    #93
    Bro pag distilled water like yung sa mga naka-bottle sa stores (wilkins,Etc) hindi hard water yun kase "pure H2O"...
    walang ibang nasa water kung hindi molecules ng water na H2O..hehehe...
    yung binibili mo for your house sa mga refilling stations, soft water na din ata yun, kase dumaan na yun sa reverse osmosis...
    pag nag buhos ka tubig from maynilad na source/gripo, Pag natuyo meh makikita ka circles na parang white sa paint, yun yun mga minerals na naiwan after the H2O evaporated...
    so pag sa radiator yun nilagay at uminit na kung saan saan didikit yung mga minerals at salts... tapos overtime maipon at pwede makabara at reduce cooling, or worse rust...
    Aug 2005
    #94
    why not?
    dito sa Pinas mas concerned tayo sa radiator ng sasakyan kesa sa kalusugan ng tao
    You have problems. You're unnecessarily bumping up the threads when people have legitimate questions they want answered.
    Dec 2009
    #95
    What type is your water? The Water Quality Association of the United States defines hard water as having dissolved mineral hardness of 1 GPG (grain per gallon) or more. Here is a helpful table to show the hardness of water: (Chemistry of Hard and Soft Water)
    Soft Water- less than 1 gpg
    Slightly Hard- 1-3.5 gpg
    Moderately Hard- 3.5-7 gpg
    Very Hard- 7-10 gpg
    Extremely Hard- over 10 gpg
    water from faucet--- hard water
    water from refilling stations---soft
    water from rain( rain sa province hindi sa urban area)---soft
    water from distillation---soft
    water from poso/wells----hard
    Quote Originally Posted by miko101130 View Post
    Very Hard- 7-10 gpg
    Sa dinadami ng binasa ko ito pa maaalala ko ng husto.
    BTT: I use distilled water from local refilling station & caltex poison long life coolant.
    Aug 2005
    #97
    Very Hard- 7-10 gpg
    Water from faucets vary in hardness depending on location. But this is pretty much spot on as a rule of thumb.
    #98
    why not?
    The tragedy of it all is that... there is truth in this statement.
    Aug 2005
    #99
    If it was said by someone who has genuine sympathy for people it would have more credence.
    Then again here's a bit of an argument against frequent coolant changes: what you discard goes into the environment.
    If we did care well enough for our environment and health we'd take the time to know what we are doing right and what we need to improve on. The problem with ranting is that it gets nowhere.
    Jan 2011
    #100
    Your distilled water does nothing, it is a placebo at best in most applications, unless you're comparing it with ground water.
    Sir clarification lang, Kung yung distilled water is considered soft water, What do you mean sa statement above? Thanks!
Why Water Quality Matters
