Page 2 of 10 FirstFirst 123456 ... LastLast
Results 21 to 40 of 197
    Jul 2010
    #21
    Nakaka nosebleed. Hehe
    #22
    the coolant does not minimize water's ability to dissolve anything. what it does, is prevent the "anything" from forming in the first place.
    the coolant, thru the magic of chemistry, prevents the metal from reacting (for example, becoming an oxide, or residue, as it was called). it is the new metal compound (oxide, etc) that dissolves in the water, not the base metal. cause enough metal to become an oxide, and you eat out the metal, and eventually get a leak.
    while this oxide formation may not have been much of a problem in the olden days when engine blocks were made of iron, they are a distinct problem now because engine blocks are made of aluminum alloy, and aluminum is a reactive metal. thus the need for coolant additives (to slow down or prevent the metal from corroding)..
    that white residue in the previous second picture.. i never saw them in my father's iron engine block 's radiators. can't be from the cylinder lining.. cylinder linings today are still iron, not aluminum. and everyone knows iron oxide is rust-colored, not white (heh heh). it's probably the corrosion product of aluminum in the engine block, something coolant additives are supposed to prevent.
    dissolved molecules do not clog coolant passages, so let us not prevent water from dissolving anything. in fact, we want the water to keep everything in there, dissolved!
    and distilled water is actually prefered over non-distilled water, because it does not have impurities that deposit as solid "residue" on the metal surface (like the first picture), that ultimately block the coolant passages in the radiator and in the engine.
    and the ions in the water alluded to above, are not the cause of corrosion; they the product of corrosion.
    but the presence of ions and "oxygen molecules" (whatever that means), does not make anything a certainty, except that it has ions and oxygen molecules.
    let us not get confused with reactants being mistaken for products, and products mistaken for reactants.
    the bottom line: " we want to prevent the residues from forming. but if and when they do form, we want them to remain dissolved in the coolant."
    so, why should we not use well water in our radiators? because it contains calcium compounds. and when this well-water is heated in the engine, insoluble calcium compounds (calcium carbonate, for one) are formed and deposit in the walls of the engine block and radiator. these appear as flakes of hard, bone white material. they clog passageways and hinder heat exchange.
    and again: dissolution is not reaction.
    Aug 2005
    #23
    No one is contending the differences between those two processes.
    But here's a reason why you don't want to be dissolving everything in there all the time.
    Distilled water is essentially a hypotonic solution as a basis of extreme comparison will dissolve more. Most coolants limit the ability of water to dissolve by its very nature. A more hypertonic solution will dissolve less. But it really doesn't matter using distilled water in engines as they lose that purity as soon as it touches anything.
    Glycol simply changes the boiling and freezing points of the water and reduces its conductivity. Corrosion inhibitors and other additives introduce other properties such as lubrication and protection from cavitation. It is this protective film that you do not want water to dissolve. And practically most oxide films actually protect the metal underneath it, hence why you don't go out cleaning the patina off statues. and the domes of churches,
    The erosion of linings are a function of cavitation and oxidation. They essentially get pounded by micro-bubbles that form in the process of heat transfer. Given those places are just that hot being next to the actual process of combustion, that microscopic vapor layer is what causes pitting (apart from reduced conductivity), and the coolant then just takes those particles around for a ride.
    Now with an exposed layer to a water-based solution and its just a matter of rinse repeat until you get your nice tiny breaches leading to your tubig at langis episodes.
    But going back to the topic, the composition of the water varies greatly depending on its source. The dissolved gasses and solids (more of the solids actually) also become an issue especially when the water component evaporates as seen in the photographs as they get deposited all over the engine. You do not want to use well water unless its an emergency.
    Essentially proper flushing is critical when you come around to swapping your radiator. Replacing your coolant with a proper mixture is just as paramount.
    Aug 2005
    #24
    Clarification: oxides of iron and aluminum aren't water soluble.
    The residue seen are deposits of metal oxides and other dissolved minerals from the water.
    The process of clogging has both mechanical and chemical aspects depending on the metals available in the loop.
    Point is if you don't clean your system and you fill it up with the wrong coolant you're eventually going to be screwed.
    Jun 2012
    #25
    Quote Originally Posted by EVO-V View Post
    Pardon the ignorance but how to de-clog the water passages in the engine block, the radiator, or the metal tubings without overhauling them? Anything similar to a "liquid sosa" to flash the deposits out?
    Dec 2009
    #26
    8 years na yung radiator since nabili yung vehicle namin...
    Nung nag drain kami wala ako nakikitang any rust or solid particles that came off...
    visually wala rin scales dun sa passages sa loob...
    I just used caltex coolant and petron coolant and distilled water... for 8 years... when we replaced the thermostat, there are no rust nor any particles on the metal tubes..
    lately i've been using Baldwin BTA additives.. pang heavy duty application....
    Coolant plus distilled water would be fine...
    every year lang drain and replace para sure na meh active ingredients pa yung coolant..
    the traditional coolant gets depleted overtime...
    the newer "extended life coolant" with carboxylate inhibitors will allow the coolant to go at least 600,000 miles, 6,000 hours or 6 years before a coolant change.
    carboxylate inhibitors in ELC deplete very slowly...
    yung traditional kasing coolant, the additives get depleted easily, Nitrites, Molybdates Etc...
    halos parehas lang naman offer nilang benefits
    corrosion,scale,rust protection
    prevent cavitation erosion
    cooling sytem problems
    scale---- deposits on high temperature area, resulting in uneven metal expansion, scuffing,snoring, ring wear, crack heads
    solution- ----keep salt minerals in suspension so that they cannot deposit on engine metal surfaces or clog passages(coolant)
    acidity---corrosion of iron, steel and aluminum parts
    solution--- neutralize acids (coolant)
    cavitation erosion---allows coolant to enter combustion chamber or crankcase
    solution--- coat cylinder liners with thin oxide film to protect from erosion(coolant again)
    aeration---air bubbles that increases the probability of an engine experiencing cavitation erosion
    solution--- Coolant again with anti foam properties...
    daming benefits ng coolant....
    mura lang naman yan guys...
    tapos once a year lang...
    para iwas problems in the future..
    Aug 2005
    #27
    Quote Originally Posted by confused shoes View Post
    Actually sosa does a really good job at decloggling. But it can also react with plastic tanks an o-rings and aluminum.
    If and when you do use this flush the rad vigorously.
    Thing is there is a reason why your radiator got to that point. Will elaborate on this latrr
    Aug 2005
    #28
    Addendum in case nitpicking creeps in. oxides are suspended in the coolant and not dissolved. If you end up having metal salts in your solution you either have those as additives or you need to check what has gotten into your coolant.
    Aug 2005
    #29
    Annual draining is one thing we will differ on. But it is commendable that you have this routine in place.
    Aug 2005
    #30
    In addition to this, thermal expansion on the radiators, especially the majority of the ones made locally, wherein the cores are "floating" or when they have a "dead" tube acting as core support are designed to fail prematurely. The OEM radiators actually have formed (yes stamped) braces that reinforce the core to counteract expansion. This is a design issue that will be tested if there is a build up of deposits and pressure. Essentially your radiator expands as temperatures and pressures go up and contracts as it goes down.
    The presence of water has everything to do with why these metals react. Distilled water is an option but not necessary unless the water in your location is very hard, i.e. high concentration of dissolved minerals.
    Not necessarily an oxide layer, but a film that clings to the lining and channels via surface tension and is renewed by the circulation of the coolant itself.
    There are a few things that actually eliminate all these entirely. But a properly primed system during a fill would help minimize bubbles.
    You're spending a lot then, are you running heavy vehicles?
    Dec 2009
    #31
    personal preference ko lang yan... mura lang naman over the counter coolant like caltex and the likes eh...
    the baldwin supplemental coolant additive cost just 250 pesos.. will treat 16 gallons per pint...
    tapos protected na yung cooling systems mo...
    Aug 2005
    #32
    Quote Originally Posted by miko101130 View Post
    If it gives you peace of mind. But normally, and I say this as a qualified statement, there are coolants that last you longer and saves you the time.
    There are those that even save fuel.
    #33
    Q lang mga gurus. Is it necessary na lagyan ng distilled water yung radiator after flushing the old coolant para "ma-drain" ng husto bago lagyan ng new coolant?
    Or drain the old, then pour the new coolant pwede na?
    Oct 2011
    #34
    It wont do any harm if you do flushing after draining your old coolant.
    Aug 2005
    #35
    Drain, flush, rinse, refill.
    Flushing with distilled water is a waste of money. As long as the water is clean and that it is not hard, you should be fine.
    #36
    Thanks guys.
    May 2011
    #37
    nosebleed! bloody english man!
    well, as for my "practice" - once or twice a year, i drain the rad of my 15yr old car.
    1Gal(2L lan ginagamit) of wilkins distilled water + 2 liter of Prestone Coolant (concentrate). 50:50 mix.
    My car's rad usually consumes 1Gal++ kapag fully drained. OEM Aluminun plastic top (Calsonic).
    Then the premixed solution na prestone din, 500ml goes to the reservoir.
    1-2x a week of visual inspection helps too. Sometimes at the morning before i start the engine -
    i open the rad cap, start the engine and observe the water sa rad. Rev ng konti at tingan kun sumasabay ang tubig,
    this way for me is for checking for my water pump. Dito ko rin tinitingnan kun me mga dumi-dumi na yun tubig.
    Check the hoses too, pinipisil ko eto when cold and determine kun palitin na.
    ooops cooling system na pala eto.
    May 2009
    #38
    A few pointers peeps.
    1) A properly maintained cooling system shouldn't need overhauling. There is NO SUCH THING as a regular radiator overhaul.
    2) Not all radiators are created equal. There are those made to be disposable. A good radiator saves you the expense and inconvenience of having to replace it prematurely.
    3) Proper installation is important. A moron of a mechanic can screw up even something as basic as a radiator installation.
    4) A radiator swap is always cheaper than an engine rebuild.
    5) Use distilled water (with the right coolant additive)
    Aug 2005
    #39
    Quote Originally Posted by miked View Post
    Your distilled water does nothing, it is a placebo at best in most applications, unless you're comparing it with ground water.
    #40
    Unang beses ko iddrain to sir. 5 yrs na kasi and recommended sa manual kada 5 yrs papalitan. Mula bnew di sya nabawasan sa reservoir.
    What do you mean by rinse? With distilled water pa rin ba although di na pupunuin yung rad? Sorry got a bit confused there. Btw still planning to use OEM Toyota Long Life Coolant.
Why Water Quality Matters
