Results 1 to 10 of 58
- Nov 2002
- 82
November 29th, 2002 07:33 AM #1is it advisable to use flushing chemicals in cleaning your radiator does it really declogg and removes the rust in the radiator`..... :roll:
November 29th, 2002 08:35 AM #2
some ways, it helps. pag talagang madumi na o seldomly flushed yung radiator. yung radiator kasi accumulates rust and dirt, which hardens up over time. these flushing chemicals might help in dissolving those accumulated dirt. although using flushing chemicals is not better than doing a complete radiator cleanup which some shops does.
- Nov 2002
- 82
November 30th, 2002 04:56 AM #3ok thanks pero di kaya harmful sa loob ng makina ang mga chemicals na yun nasa ace hardware ko nakita
November 30th, 2002 08:46 PM #4
Hindi naman papasok sa makina yung radiator flush chemicals. Hanggang water jackets lang sila ng engine block mo.
November 30th, 2002 09:43 PM #5
Radiator flushing is good as long as di pa luma yung makina. Pag nag flushing kasi, tinatanggal nung chemical yung mga accumulated rust. Ang problema, pag may kalumaan na yung makina (engine block) pati yung mga maliliit na particles nung block natatanggal.
To elaborate things further, may mga parte ng lumang makina na lusaw (metal flakes) na dahil sa kalawang pero hindi parin tinatagusan ng tubig dahil makapal pa ito. Pag dinaanan ng flushing ito matatanggal lahat nung lusaw na parte ng makina at ninipis yung parte na pinanggalingan nito. Ang magiging epekto nito ay ninipis yung metal at sa konting pressure lang ay bibigay na agad at pagsisimulan na ng tagas.
Lahat nito ay ayon sa aking ekpiryensya lamang. Ginamitan ko ng radiator flushing yung makina na walong anyos na at pagkatapos ng ilang araw ay nakita ko na sa loob ng radiator yung mga metal flakes at sinundan na ng tagas ng tubig mula sa block ng makina.
just my two! :mrgreen:
- 237
December 1st, 2002 02:56 AM #6sir,
ano ba magandang maidudulot ng malinis na radiator?
tuwing kelan dapat ipalinis un?
- Nov 2002
- 82
December 1st, 2002 05:19 AM #7i think kaya dapat i flush ang radiator ay para malinis ang passage ng water sa block ng makina for better cooling ng makina para di mag overheat di ko lang alam kung every ilang years before you do it :lol:
December 1st, 2002 01:58 PM #8
After cleaning your radiator, put a coolant with rust inhibitor specially when you use ordinary tap water in your radiator. For best results, use distilled water to prevent mineral(the same mineral deposits you see inside your kettle) build up in your radiator. HTH :wink:
December 1st, 2002 04:48 PM #9
palagay ko mabuti pa pa-overhaul ng radiator 200 lang kesa abala sa pag alis ng natirang flushing fluid. masama kasing may matira sa radiator and yes baka masira water jacket. gagamit ka pa ng distilled water, paano kung kailangan mo na magkarga pero wala distilled water? overhaul na lang less hassle pa.
December 2nd, 2002 01:53 PM #10
GoThicbLuE, kung wala namang tagas ang cooling system, di na kailan magkarga nang magkarga ng tubig. Yung dating ride ko di ako nagdagdag ng tubig sa loob ng 2 years dahil di naman siya nababawasan. Gumamit lang ako ng distilled water nung nagpalit na ako ng coolant. Nang masira ang radiator cap ko, saka lang ako nagdagdag ng tubig at distilled water ang ginamit ko para walang contamination ng minerals. You will notice a big difference sa radiator na gumagamit ng tap water at radiator na gumagamit ng distilled water. Para sa bagong linis na radiator(through flushing or overhaul), it would be better to start right by using distilled water. Less problems pa in the future in terms of maintenance kasi naiiwasan ang pagbabara ng radiator. If a person finds it more convenient to use tap water, I suggest he puts a coolant that contains rust inhibitors to prevent clogging(rust and minerals) and have a better cooling system at the same time. :wink:
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
