Results 51 to 58 of 58
- Jul 2003
- 48
October 5th, 2003 11:48 AM #51what's the best available coolant in the market? Pansin ko lang po kasi malakas magputik sa reservoir yun coolant ng Petron. ethylene glycol naman po lahat sila, di ba? Lahat po ba sila ganito?
October 5th, 2003 12:46 PM #52
Baka may sludge na sa loob ng mga water jackets and other cooling system parts mo.
Gusto ko yung sa Caltex kasi long life siya.
- Nov 2002
- 51
October 5th, 2003 06:37 PM #53I agree with Sir Otep.
I think the best coolant available is the Caltex Extended Life Coolant since based from it's label ay di mo kailangang palitan ng up to 5 years or 200,000 kms. It means maintenance savings. Pero twice ang price niya compared to the regular coolants. I had it placed in my Strada.
- Jul 2003
- 48
October 5th, 2003 10:22 PM #54sir otep ; oo nga eh. 20T kms pa lang yun xwind ko. di naman tumataas yun temp gauge kaya lang ever since petron coolant na yun ginagamit ko. try ko caltex coolant. kaya lang would you recommend na paflush ko muna o pwede na diretso lipat na?
October 5th, 2003 10:44 PM #55
Sir Scanner,
Drain the coolant from your radiator as I described and fill it with the recommended 50:50 coolant:water ratio of your desired coolant. Maganda na din po ang Petron Coolant. You don't need to change it right now kung wala naman pong problema. I suggest you do it at your manufacturer's recommended schedule wich is usually 40k or 2 years. Goodluck.
- Jul 2003
- 48
[/url] [url=https://ibb.co/ZdFj7Nv] I also use Fram Ultras sa iba kong oto. Xg3600 sa...
Best Oil/Fuel Filters
