Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
    #41
    Quote Originally Posted by huntsman View Post
    ung sakin walang thermostat.simula yata nung ako na nagatake over e wala na yata..ok lang ba na wala?
    your engine won't die prematurely, if that is what you are worried about.
    a thermostat prevents coolant inside the engine block, from circulating into the radiator.
    as a result, your engine gets up to its optimal working temperature, faster.
    while that engine is cool, the computer gives it more fuel, sort of "choked".
    as a result, engines running cooler than their optimal working temperature, consume more fuel.
    bottomline, a working thermostat helps you save on fuel, and lessens pollution.
    Sep 2016
    #42
    Quote Originally Posted by Maximo74 View Post
    sir, kaso sabi dun sa shop e meron leak yung radiator ko, hindi nila ma-compression test. try ko muna fix yung radiator.
    worst case na kapag me problema CH.
    can you recommend a shop para sa top overhaul. cavite area, pwde na rin d2 sa manila. yung hindi taga masyado. any idea how much? para mapaghandaan na.
    Update mga sir.. nagpalit ako ng bagong radiator, same issue pa rin.. after long drive from cavite to manila, puno ang reservoir tank at walang tubig ang radiator. nasa kalahati ang temp. reading. ok ang fans.
    positive na problema nga kaya sa CH?
    Jul 2016
    #43
    Baka radiator cap lang yan sir
    Sent from my SM-J500G using Tsikot Forums mobile app
    Sep 2016
    #44
    bago din yung rad cap, same sukat dun sa bagong radiator. dalhin ko sa speedyfix bukas para sa compression test.
    Sep 2016
    #45
    ung sakin palaging ubos coolant ung reservoir. kaya di ko na linalagyan ngayon. pero di naman nababawasan dun sa radiator. sa reservoir lang nagbabawas.kapapalit ko lang head gasket.
    May 2009
    #46
    baka naman may butas ang reservoir plus syempre nagii-slosh ang laman kapag tumatakbo na ang sasakyan at natatapon sa may takip mismo.
    make sure na may thermostat yang makina mo brader.
    Jul 2016
    #47
    Yung orig kunin mo rad cap sir.
    Sep 2016
    #48
    ok nman sir yung rad cap, japan made din same sukat para sa radiator. pero try ko din bumili sa Toyota.
    Update sir sa compression test sa speedyfix. readings - 160-150-150-175.. ok nman daw ganun na reading. wala leaks. hindi rin nila masabi kung ano problema base dun sa compression test. ano pa kaya kelangan test para ma-pin point ang cause ng overflowing coolant sa reservoir at dry ang radiator.
    talked to the owner of speedyfix and he suggest na complete overhaul talaga kse dun malaman kung meron crack ang head, warped and cylinder or just simple palit lang ng gasket at oil seals. pero not a guarantee na yun nga ang culprit. big amount of money rin kaya hindi ako maka-decide kung ipa-overhaul ko.
    #49
    Sir yung upper at lower hose maganda pa nman ang pagka-rubber. not so sure sa mga clamps at clips nya kse ilang beses na inalis yung radiator, pero lagi ko rin check wala nman tagas or traces ng coolant.
    yes sir bago palit yung thermostat.
    OEM thermostat ba ang ipinalit mo sir?
    a faulty rad cap could be the culprit. kahit bago pero kung wala naman sa specs,,,wala din imo.
    though i think not necessarily complete overhaul agad iyan. pero kailangan nang mabuksan ang cylinder head then see kung warped whatsoever then start there.
    extreme overheat kasi iyan kaya most likely may tama iyan sa loob.
    Apr 2009
    #50
    Is your new radiator the OEM or a replacement brand? It could also be that your water pump is leaking but not overt and leak dries up immediately with the warm engine. You mentioned the first time that your car overheated and it died along the way. this is not a good sign and could probably mean a warped or cracked cylinder head. check your dipstick if your engine oil is "milky" in character. Oh, in most toyota vehicles that i've seen and owned, i never saw a radiator cap with a 1.1 rating...
    Feb 2009
    #51
    Did anybody in any of the shops you mentioned perform pressure test on the rad cap and the cooling system? There had been too many v Hunches and your car is still overheating. Do a proper diagnosis first
    Sep 2016
    #52
    Quote Originally Posted by LN106G View Post
    Sir replacement brand yung radiator, bagong palit ang water pump at thermostat. walang makita na leak anywhere sa mga hoses, etc. walang signs ng kahit ano sa dipstick, takip ng engine oil, walang any sign of water or oil sa spark plug sockets. rad cap bago rin. Pinalit ko sa orig rad cap ng vios then long drive, same issue pa rin.. baka dun na ako sa top overhaul pagnagkaron ng budget. salamat mga sirs..
    Apr 2012
    #53
    Oct 2009
    #54
    aba high pressure na nga siguro yan.tanggalin mo nga ung rad cap mo saka mo paanadarin kapag may bula bula na lumabas sa radiator mo malamang mag pa top overhaul kana..kung rad cap problem mo
    Aug 2016
    #55
    Replace it.
    Engines don't like running cold.
    meron pa ba nabibiling thermostat dito sa Pinas?
    baka kasi mapagsabihan nanaman ako sa parts store na "napakainit dito sa Pinas, di mo kailangan nun!" eh from what i know parang bypass naman ang thermostat pag mainit na ang makina, and it just helps the engine warm up faster so the efi system would go closed loop faster, therefore mas matipid sa gas...
    Jun 2005
    #56
    Quote Originally Posted by carguy101 View Post
    Oo naman. Sa banawe madami. Sa pasay din
    Aug 2016
    #57
    Quote Originally Posted by sirkosero View Post
    ahh sige thanks.
    kasi nun one time sinabihan ako ng tao sa parts store nun bumibili ako ng langis na hindi ko kailangan ng multigrade oil dahil "napakainit dito sa Pinas"
    Jun 2005
    #58
    Sabihan mo lang na, gusto mo lang naman sya payamanin sa mas mahal ng multigrade kaya shut up na lang. Haha
    Aug 2016
    #59
    tama tama! hahahah
    thanks for the tip [emoji108][emoji817]
    Feb 2009
    #60
    Kids please do you homework.
Overheating?
