Results 1 to 17 of 17
    Oct 2013
    Car: Toyota Avanza AT 2010
    Mga sirs
    Question lang regarding Aircon/Radiator problem
    So sa unang 15mins run, okey yung aircon but after that yung buga nia is wala ng lamig tapos tumataas yung temp gauge sa dashboard. so pinapatay ko yung aircon.
    Ok naman ung sasakyan sa long run pag wala ung aircon.
    Then, malakas consumption ng coolant. naubos yung 1/4 part ng overflow tank. wala namang leaks sa tubes. Wala ring white air sa discharge ng exhaust pipe. wala ring oil sa radiator pag inalis ko yung cap.
    Ano kaya problem dito mga sirs? Dahil ba sa thermal switch ng compressor na pag naghigh discharge si freon ay mamamatay ang compressor?
    Pero yung root cause, bakit nauubos yung coolant? dahil ba sa sirang cap?
    Eto sirs condition ng cap
    San kaya pwede ipaayos to?
    Thanks in advance.
    Sent from my SM-J700F using Tsikot Forums mobile app
    Jun 2011
    Quote Originally Posted by misterioman View Post
    Mga sirs
    Thanks in advance.
    Check first your Aircon Fan-- and radiator fan... It might be the culprit..
    Aug 2015
    Kung nauubos ang coolant baka may leak ang rad mo sir. Have it tested baka minimal fee lang yan.
    Mga sirs
    Thanks in advance.
    my guess? your aux fan is defective. it might not be turning as fast as it should. that is why, it seems to be working ok when you look at it. hindi na malamig aircon, overheat pa engine. when the engine overheats, the steam escapes to the coolant reservoir, heating it so that it also turns to steam. ubos radiator coolant, ubos reservoir coolant.
    look for the same model vehicle as yours, and observe how strong the air movement should be.
    good luck.
    also check if the thermostat(engine) is still ok.
    Feb 2009
    Mga sirs
    Thanks in advance.
    your air conditioner or climate control is affected by all of the following:
    1 ambient air temperature
    2 engine cooling system temperature
    3 engine speed
    4 powertrain control module
    5 the compressor drive belt
    6 refrigerant purity/type and pressure
    7 system component condition (e.g., your compressor, thermostatic expansion valve, etc. etc)
    8 air flow across the condenser
    9 air flow across the evaporator.
    assuming everything else is normal, since you have coolant loss and of course beyond any reasonable doubt, will be overheating. if the engine temperature is high, the a/c system will not work by design. if the coolant temperature sensor mimics or simulates an overheat condition, the a/c system will not be enabled.
    Mga sirs
    Thanks in advance.
    Kung sa rad cap lang duda mo. Bumili ka lang ng replacement nyan. Patungkol sa aircon naman. Paano mo nasabi mag high discharge at mag cut off yun compressor mo? May test gauge ka ba? Patungkol sa pagwala ng lamig sa aircon mo, marami factors maaari pagmulan nyan.
    Starmobile Up+
    Jun 2011
    Radiator cooling fan motor baka mabagal na umikot.
    What's the mileage and age of your Avanza?
    Do you see any residue of where the coolang is seeping out? Check your radiator cap and coolant reservoir.
    Things to check first:
    Auxilary fan
    Radiator cap (always replace with original or Denso brand)
    Water pump
    Radiator hoses (clamps)
    Oct 2009
    hi temp sa AC system.
    sira ang fan ng condenser kaya high temp ang AC system mo.kaya nahihirapan ng umikot ang compresor.pag hirap ng umikot bibigat ang hatak ng makina.
    mainit na ang condenser na katabi ng radiator kaya nag iinit nadin ang radiator mo.check mo din ang rad fan mo baka mabagal na ikot.check mo pareho paandarin ang makina saka AC tapos obserbahan mo ng mga 20 mins taas mo ang hood para makita mo kung umaandar ng normal ung cooling system mo.
    Oct 2013
    Just to update.
    Sira na ung fan ng radiator. mahina na yung ikot compared to a normal one. Pinalitan yung motor.
    Then, okey na! Wala ng overheat, ok na ang aircon kahit tirik ang araw, di na nababawasan coolant. Hindi rin sira yung cap ng radiator.
    Eto pala yung prices ng motor ng aux fan for reference.
    (Toyosco)
    2.5k - Circuit
    4.5k - Denso
    9k - Toyota brand
    Thanks tsikoteers! Hope to helo din in the future.
    Just to update.
    (Toyosco)
    2.5k - Circuit
    4.5k - Denso
    9k - Toyota brand
    That's good news. You found the problem and able to resolve it. Which of the three brands you choose to purchased and installed?
    Starmobile Up+
    Oct 2013
    Circuit. No budget sir e.
    Sep 2014
    payo lang don't buy the circuit brand. sigurado na sira ng buong cooling system mo as well as aircon system
    that's brand is just plain trash
    Jun 2005
    Wow mahal! 1300 lang ang fan motor na circuit ang brand...
    Agree... walang kwentang replacement brand yan
    Sep 2016
    good day tsikoters. ask ko lang kung ilan litro coolant ng corolla altis 2005. pahingi ng link kung me kagayang thread. wala po kasi sa manual. salamat
    Nov 2016
    Possibility po weak na nga ang fan, isabay mo na din po yung radiator cap
Aircon / Radiator Problem
