Results 11 to 14 of 14
October 11th, 2014 10:34 PM #11
Look for shops that give at least 2months warranty... Para pag nag leak ulit.. Wala ka pong gastos... Pero kung in a month palang mawalan na ng Freon baka hindi sa pito yan... Kasi dapat kita nyo agad na ma oil yun... Imo May leak yan.. I think they should re-do everything again... Pull down the hoses, evaporator, condenser.. Pag sa compressor makikita naman agad yan... I suggest pressure test nila evap, at condenser nyo then ilubog sa water....
- Mar 2010
- 2,273
October 12th, 2014 08:31 AM #12if there is a drop in pressure, definitely there is leak somewhere, and they have to find it!
Ito ang mga ginawa sa akin ng kumpare kong may ari din ng AC shop.
pinalitan nila yung compression fitting connection, due to frequent kalas/balik; cut the old fitting and weld new one.
palit din ng o ring sa filter drier
palit din compressor o ring sa head cover, nung una yung shaft seal.
hindi sila tumigil sa paghanap sa possible source ng leak hanggat nagbabawas ng pressure yung system. They pressurize the system with the highest possible pressure 250 psi o 300 psi yata di ko na matandaan, using nitrogen, with the aid of soapy foam in finding the leak.
- Oct 2009
- 2,271
- May 2014
- 72
October 16th, 2014 06:42 PM #14
if you purchased your car recently... nasa OR kung hanggang kelan valid yung registration mo. If...
1st LTO renewal after 3 yr registration
